[snappyHexMesh] Problem with prism layers at corner edges
Old   September 12, 2016, 11:37
Default Problem with prism layers at corner edges
Paul Palladium
Fauster is on a distinguished road
Dear Foamers,
I would like to know what is the wrong with my SHM's settings. I am doing a wind loading simulation (16 M Cells) and my prism layers are really bad at corner edges. You can see this on the picture attached to my message.
The prism generation crash at corner edges even if I have (I guess) a correct setting on SHM :
// When not to extrude surface. 0 is flat surface, 90 is when two faces
// are perpendicular
featureAngle 180;
// At non-patched sides allow mesh to slip if extrusion direction makes
// angle larger than slipFeatureAngle.
slipFeatureAngle 75;
Generally "an optimum value of 180 or higher is recommended to grow layers at corner edges" according to https://www.simscale.com/docs/conten...dSettings.html
Could you help me ? What did I do wrong ?
Thanks a lot,
Regards
EDIT : 16/09/2016 :
This post could be helpful : http://www.cfd-online.com/Forums/ope...r-corners.html
It seems that featureAngle 180 is not the best setting to grow layers at corner edges. featureAngle 60 could be better...
Fauster is offline   Reply With Quote
Old   September 30, 2016, 00:25
me3840 is on a distinguished road
Your edges are very jagged. Did you use surfaceFeatureExtract?
me3840 is offline   Reply With Quote
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 09:42
[ICEM] How to avoid squished Prism Layers in refined regions Hamps ANSYS Meshing & Geometry 0 February 15, 2019 11:20
Prism Layers at Slip Wall to Non-Slip Wall Transition InfernoxCJC STAR-CCM+ 4 November 26, 2017 19:06
Trimmed Cell Mesher and Prism Layers Jack220 STAR-CCM+ 4 August 7, 2013 10:57
[ICEM] Creating a prism layer causes problem.. earth07 ANSYS Meshing & Geometry 1 June 3, 2013 10:28
