[mesh manipulation] BlockMesh cellSet refineMesh
Like Tree17Likes
Old   November 13, 2008, 13:35
Default BlockMesh cellSet refineMesh
Mattijs Janssens
mattijs is on a distinguished road
refineMesh by default refines the whole mesh. Use
refineMesh -dict
to refine according to the dictionary.
mattijs is offline   Reply With Quote
Old   November 16, 2008, 20:56
Default Thank you very much for your h
Axel Mohr
alexm is on a distinguished road
Thank you very much for your help. This has been the fine but important information, I needed.
In my refineMeshDict above seems to be a little mistake. The third refinement direction should be named as "normal", not "tan3":
directions
tan1
tan2
normal
alexm is offline   Reply With Quote
Old   August 26, 2010, 00:51
Default refineMesh tetrahedral
Hrushikesh Khadamkar
Hrushi is on a distinguished road
refineMesh -dict
Hi mattijs,
Does refineMesh utility works on tetrahedral mesh? If no, is there any other utility available in OpenFOAM to do that?
Hrushikesh
Hrushi is offline   Reply With Quote
Old   September 21, 2010, 03:26
Maulik is on a distinguished road
how does tan1, tan2 get calculated while refining Mesh?
I am new to CFD so couldnt get how does it calculate...
please help me out..
Thanks
Maulik is offline   Reply With Quote
Old   November 16, 2010, 05:53
Default Solution for a faster refinement
Frank Whittle
challenger is on a distinguished road
Hello Mattijs,
I am using refineHexMesh to refine different parts of my domain. Since I have around 10 different refinement parts, after the first few, it starts getting really slow.
My assumption is due to the entire domain being under consideration for refinements. Can I isolate it with sets and just include that region during refinement so that the process is much faster then later combine these sets or merge it into the main mesh file?
Challenger
challenger is offline   Reply With Quote
Old   November 26, 2010, 04:03
lindstroem is on a distinguished road
Hi there,
as you are using the refineMesh utility I would like to ask you, how to use it. I found out, that the "refineMeshDict" has to be in the system/ folder. When I start refineMesh -dict it says that the file
user-1.7.1/run/cases/mesh/constant/polyMesh/sets/c0 at line 0.
cannot be found.
The mesh was created with the blockMesh-command and is simply a box. How do i get the sets "c0" and so on?
Thanks for your help!
lindstroem is offline   Reply With Quote
Old   November 26, 2010, 04:53
Frank Whittle
cannot be found.
[In 1.6] (should be the same for 1.7)
In order to refine a mesh, you need to specify which part or which cells are being selected. To do this, use the command setSets, this creates set which are later used by the refineMeshDict to refine the mesh.
then include this set name in the refineMeshDict in order to refine those cells.
setSet requires a batch file the file is just an info on which cells are selected. this is what I do,
cellSet ref new boxToCell (-10 -35.0 -10) (10 35 87.6) > refinement
setSet -batch refinement -latestTime
refineMesh -dict
the dict should include the refinement set name. in this case its ref
Hope that helped.
Cheers!
Luttappy likes this.
Old   November 26, 2010, 05:07
Hi challenger!
Thanks! Yes, it helps! I just started with the cellSetDict to create the sets which should be the same what you are doing with cellSet command. I just refined my first "little area". Now I'll see how it works with multiple cellSets and maybe I'll have a great weekend
Greetings!
Old   October 31, 2011, 10:54
giovanni silva
giovanni10 is on a distinguished road
Hi challenger!
Greetings!
Could you explain me how I can refine a specific region in a cavity? What can I do exactly? Thanks in advance!
giovanni10 is offline   Reply With Quote
Old   January 16, 2013, 08:49
emirust is on a distinguished road
Foamers!
Do anybody know what to specify if I want to have an extra refined mesh in a region?
By default, refineMesh divides cells in 4 for a 2D case, or by 8 for a 3D case. I would like the refinement to be better than this.
Thanks!
emirust is offline   Reply With Quote
Old   January 16, 2013, 08:55
Nicklas Linder
nlinder is on a distinguished road
you can run it twice, or as often as you need it...
nlinder is offline   Reply With Quote
Old   January 16, 2013, 09:22
Tried, but doesnt serve my purpose of increasing the cell resolution in the central part (as seen in screenshot where I ran the utility three times)
Old   January 16, 2013, 09:42
Nicklas Linder
I do it quite often, but maybe different. You can see it in the attachment. I have several cellSet Files with some space in between them. So I run cellSet (with file 1) refineMesh, then the next CellSet and again refineMesh and so on..
edit: and maybe switch of decompose polyhedrons in paraview...
lifeinhand, Luttappy and mdk1 like this.
Old   January 17, 2013, 03:24
Ok! It will serve my purpose, and you screenshot is exactly what I am looking for .
How did you automate this? I need to do it maybe 8 times, and modifying the dict files each time is not a good solution.
How do you create your cellSets? Do you have a cellSetDict you manually edit for each refinement? Ideally, I could create the sets from the command line so I can include it in my shell script...
Thanks!
Old   January 18, 2013, 04:48
Nicklas Linder
Yes i use a script.
You need several cellSet files called cellSetDict.1, cellSetDict.2 .... I created them manually.
Then I use the following script (credits to the one who wrote it, I actually don't know)
refineMeshByCellSet()
   while [ $# -ge 1 ]
   do
      echo "creating cell set for primary zone - $1"
      cp system/cellSetDict.$1 system/cellSetDict
      cellSet > log.cellSet.$1 2>&1
      echo "refining primary zone - $1"
      refineMesh -dict -overwrite > log.refineMesh.$1 2>&1
      shift
   done
runApplication blockMesh
echo "BlockMesh finish"
refineMeshByCellSet 1 2 3
echo "refineMeshByCellSet finish"
The second last line defines how often it will be refined..
Greetings
Old   July 30, 2013, 08:17
idefix is on a distinguished road
I donīt know how to go on.
what I did so far:
snappyHexMesh -overwrite --> creation of the mesh (creation of folder 0 )
insideCells refine.stl cellSet --> creation of a set of cells from the mesh
refineMesh -dict --> refinement of the cells in the set cellSet (creation of folder 1)
everything is fine, the mesh is refined
Afterwards I want to do a refinement again (the .stl-file covers a part of the first .stl-file)
insideCells refine2.stl cellSet2
refineMesh -dict
(I changed the name cellSet to cellSet2 in the refineMeshDict)
I get the following error:
Create time
Create polyMesh for time = 1
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/home/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 in "/lib64/libc.so.6"
in "/home/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/refineMesh"
#5 __libc_start_main in "/lib64/libc.so.6"
at /usr/src/packages/BUILD/glibc-2.11.2/csu/../sysdeps/x86_64/elf/start.S:116
Gleitkomma-Ausnahme
can anybody help? What do I have to change when I want to refine the mesh twice?
Thanks a lot
idefix
idefix is offline   Reply With Quote
Old   September 23, 2013, 09:45
Gerhard Holzinger
GerhardHolzinger will become famous soon enoughGerhardHolzinger will become famous soon enough
refineMesh -dict
I don't really like this behaviour, but this post of yours saved my day!
I assumed that refineMesh uses the dictionary by default, and that the -dict option is used to point to an alternative dictionary.
GerhardHolzinger is offline   Reply With Quote
Old   February 5, 2014, 19:37
Default Problems in refineMesh
  #18
Nadish Saini
90nash is on a distinguished road
Hello Foamers,
I am new to openfoam and thus am struggling with some commands. I had created a mesh in Salome and imported it into Openfoam. I have run one analysis and now want to refine my mesh. But when i am using 'refineMesh -overwrite' command it terminates with "Aborted- Core Dumped". A bunch of files are written in my case directory but the mesh is not refined (verified this using checkMesh). I am using OF-2.2.2
Can anyone please suggest what i am doing wrong. Thank you in advance for your help!
90nash is offline   Reply With Quote
Old   February 11, 2014, 03:13
do you want to refine your whole mesh or only a part?
Old   April 10, 2014, 12:38
M. Montero
be_inspired is on a distinguished road
I suppose that this utility is not valid if I want to refine along x and y direction but not along z direction because keeping the first cell height is a must.
In that case, what utility can I use? Maybe Mesquite?
be_inspired is offline   Reply With Quote
[blockMesh] Multi-region Blockmesh - Refinemesh issues. Doug68 OpenFOAM Meshing & Mesh Conversion 3 February 18, 2016 20:09
[blockMesh] Multi-region Blockmesh - Refinemesh issues. Doug68 OpenFOAM Meshing & Mesh Conversion 0 February 17, 2016 03:39
[mesh manipulation] multiple calls to refineMesh parallel w/ dict failing Regis_ OpenFOAM Meshing & Mesh Conversion 2 June 4, 2015 13:44
[mesh manipulation] refineMesh from a cellSet issue gfilip OpenFOAM Meshing & Mesh Conversion 0 September 28, 2010 13:14
Bug in mesh tools: cellSet, refineMesh, ...? alexm OpenFOAM Bugs 0 August 10, 2009 12:46
