[mesh manipulation] MshToFoam
Old   July 7, 2008, 03:36
Default MshToFoam
Hari Krishnan
hariya03 is on a distinguished road
I have copied the .msh file converted from adventure on windows to the folder smartvalve in simplefoam
The smartvalve is a new case I created by right clicking on the case browser and by using create case command.
The mesh file is placed in the smartvalve case folder. I have not did any proceedings in system and constant directories. First I started the mshToFoam command directly.
The mshToFoam command exits as like this
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox
| \ / O peration | Version: 1.4.1
| \ / A nd | Web: http://www.openfoam.org
| \/ M anipulation |
Exec : mshToFoam OpenFOAM/harikr-1.4.1/run/tutorials/simpleFoam
smartvalve CFD
Date : Jul 04 2008
Time : 18:21:20
Host : D6
PID : 22462
Root : OpenFOAM/harikr-1.4.1/run/tutorials/simpleFoam
Case : smartvalve
Nprocs : 1
Create time
--> FOAM FATAL IO ERROR : Attempt to get back from bad stream
file: CFD at line 1.
From function void Istream::getBack(token& t)
in file db/IOstreams/IOstreams/Istream.C at line 44.
FOAM exiting
could advice me where I had make mistake?
hariya03 is offline   Reply With Quote
Old   July 8, 2008, 02:53
Default Please stop spamming the forum
jaswi is on a distinguished road
Please stop spamming the forum ...
It will never get you any productive replies but this.
Thanks
Jaswi
jaswi is offline   Reply With Quote
Old   July 9, 2008, 03:19
Default i could not understand.. could
Hari Krishnan
i could not understand.. could you clear me any wrong I made
Old   July 9, 2008, 10:41
Default What I meant is that please do
What I meant is that please do not post the same problem in multiple threads. Please stick to one thread. What you did is that you posted the same problem under three categories:
OpenFOAM mesh utilities
Preprocessing Foamx
OpenFOAM bugs
And finally you found that it was a simple mistake. Please consider others who will be searching this forum and answering to your question.
The forum is free to use but it is OUR forum , and it is OUR responsibility that we use it for help when we really need it.
Please do not take my comments negatively and Excuse me if I have said anything wrong.
With Best Regards
Jaswi
Import geometry from CAD Giuseppe (Giuseppe) OpenFOAM Pre-Processing 34 December 14, 2017 16:24
MshToFoam hariya03 OpenFOAM Pre-Processing 4 July 9, 2008 03:22
MshToFoam hariya03 OpenFOAM Bugs 0 July 7, 2008 03:37
[Other] MshToFoam hariya03 OpenFOAM Meshing & Mesh Conversion 0 July 7, 2008 03:32
