[Other] MshToFoam
Old   July 7, 2008, 03:32
Default MshToFoam
Hari Krishnan
hariya03 is on a distinguished road
I have copied the .msh file converted from adventure on windows to the folder smartvalve in simplefoam
The smartvalve is a new case I created by right clicking on the case browser and by using create case command.
The mesh file is placed in the smartvalve case folder. I have not did any proceedings in system and constant directories. First I started the mshToFoam command directly.
The mshToFoam command exits as like this
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox
| \ / O peration | Version: 1.4.1
| \ / A nd | Web: http://www.openfoam.org
| \/ M anipulation |
Exec : mshToFoam OpenFOAM/harikr-1.4.1/run/tutorials/simpleFoam
smartvalve CFD
Date : Jul 04 2008
Time : 18:21:20
Host : D6
PID : 22462
Root : OpenFOAM/harikr-1.4.1/run/tutorials/simpleFoam
Case : smartvalve
Nprocs : 1
Create time
--> FOAM FATAL IO ERROR : Attempt to get back from bad stream
file: CFD at line 1.
From function void Istream::getBack(token& t)
in file db/IOstreams/IOstreams/Istream.C at line 44.
FOAM exiting
ould advice me where I had make mistake?
hariya03 is offline   Reply With Quote
Import geometry from CAD Giuseppe (Giuseppe) OpenFOAM Pre-Processing 34 December 14, 2017 16:24
[mesh manipulation] MshToFoam hariya03 OpenFOAM Meshing & Mesh Conversion 3 July 9, 2008 10:41
MshToFoam hariya03 OpenFOAM Pre-Processing 4 July 9, 2008 03:22
MshToFoam hariya03 OpenFOAM Bugs 0 July 7, 2008 03:37
