[Other] CheckMesh for mesh quality
Old   October 16, 2007, 10:13
Default CheckMesh for mesh quality
Doug Baldwin
gdbaldw is on a distinguished road
To all,
checkMesh tells me I have one concaveFace, but as can be seen in the attached image this white face owned by the purple cell does not appear to be concave. In general, does checkMesh simply screen for possible mesh errors? I ask because this is not the first time checkMesh produced an error/warning for what appeared to me to be a good mesh.
Doug
gdbaldw is offline   Reply With Quote
Old   October 16, 2007, 14:09
Default Concavity check should pick up
Mattijs Janssens
mattijs is on a distinguished road
Concavity check should pick up where consecutive edges form a normal (right-hand rule) which points opposite to the face normal. Can't see any problems with the code itself (OpenFOAM/lnInclude/primitiveMeshCheck.C).
Does the wireframe of the concave face show the same? (VTK does not display solid concave faces correctly)
mattijs is offline   Reply With Quote
Old   October 18, 2007, 00:11
Default Mattijs, You are absolutely
Doug Baldwin
Mattijs,
You are absolutely correct. Identical views of this face displayed in paraFoam as a surface and as a wireframe are attached below. Thank you for making this clear for me.
Doug
[ICEM] Unexplained changes of mesh quality and blocking approach salumi ANSYS Meshing & Geometry 9 November 23, 2016 04:14
[ICEM] How to improve bad quality elements that are obtained after creating prism layers? Rohith Giridhar ANSYS Meshing & Geometry 2 July 11, 2015 18:04
[Commercial meshers] failed CheckMesh in spite of good quality -mAx- OpenFOAM Meshing & Mesh Conversion 2 May 24, 2013 01:48
[Commercial meshers] gambit import mesh quality problem with checkmesh mrshb4 OpenFOAM Meshing & Mesh Conversion 0 December 26, 2010 13:17
[Technical] Mathematical exact definition of mesh quality measures in OpenFOAM checkMesh utility albcem OpenFOAM Meshing & Mesh Conversion 1 October 31, 2008 04:12
