[Commercial meshers] Error fluentMeshToFoam
Old   January 14, 2009, 04:32
Default Error fluentMeshToFoam
xinguang cui
loneboard is on a distinguished road
I am the newer of OpenFoam, and now I am stopped in the begin. I hope someone could help me:
system: opensuse 10.3
version: openfoam 1.5
The grid was generated with icem in the windows xp system in the form of .msh. Then it is imported to the fluent in the opensuse 10.3.
The mesh file was exported from Fluent with ASCII.
But there is error information as follows:
cui@mfc-falter:~/OpenFOAM/cui-1.5/run/project/Simple_geometry_circular/Flow_1/system> fluentMeshToFoam sucess
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.5 |
| \ / A nd | Web: http://www.OpenFOAM.org |
| \/ M anipulation | |
Exec : fluentMeshToFoam sucess
Date : Jan 14 2009
Time : 10:19:40
Host : mfc-falter
PID : 31021
Case : /home/cui/OpenFOAM/cui-1.5/run/project/Simple_geometry_circular/Flow_1/system
nProcs : 1
Create time
cannot open file
file: /home/cui/OpenFOAM/cui-1.5/run/project/Simple_geometry_circular/Flow_1/system/sy stem/controlDict at line 0.
From function regIOobject::readStream(const word&)
in file db/regIOobject/regIOobjectRead.C at line 66.
FOAM exiting
And I also try to use fluent3DMeshToFoam, but there is the error information too.
Moreover, I have tried to import ASII file in the windows xp, and then converted to linux file format, but it doesn't work.
I have tried almost every way in the forum, but it doesn't work.
Who could help me? I feel crazy
loneboard is offline   Reply With Quote
Old   January 14, 2009, 04:42
Default Hi, you should move to Open
caw
Christian Winkler
caw is on a distinguished road
you should move to OpenFOAM 1.5.x
There, the fluent converters have been improved to handle files written under windows.
Remember: Use ASCII
Best regards Christian
caw is offline   Reply With Quote
Old   January 14, 2009, 05:01
Default Thank you!!! In fact, I hav
xinguang cui
Thank you!!!
In fact, I have converted windows file to linux format.
Do you think it is problem that I generated the file in the windows system?
Old   January 14, 2009, 05:05
Default i never succeeded converting f
caw
Christian Winkler
i never succeeded converting fluent cases generated on windows to OF in version 1.5, even when using dos2unix first.
the problem went away with the bugfix in 1.5.x
workaround: load your fluent case into the linux version and rewrite it as ascii
Christian
Old   January 14, 2009, 05:09
Default Thanks!!! I have tried to l
xinguang cui
Thanks!!!
I have tried to load my fluent case into linux version and rewritten it as ascii, but it doesn't work! Maybe I need to try to solve it openfoam 1.5.x
Old   January 14, 2009, 10:50
Default Hi I think it is just a pro
florian
Location: Mannheim - Vincennes - Valenciennes, Deutchland - France
floooo is on a distinguished road
Hi
I think it is just a problem of folder
At the bigining you ar in system instead of your case directory
cannot open file
OpenFoam look for controlDict in system folder which doesn't exist.
Try to do the conversion by lunching the command from your case directory :
cd /home/cui/OpenFOAM/cui-1.5/run/project/Simple_geometry_circular/Flow_1
fluentMeshToFoam system/sucess
Florian
floooo is offline   Reply With Quote
Old   January 14, 2009, 10:57
Default Thanks florian, i should ha
caw
Christian Winkler
Thanks florian,
i should have read the error massage more closely.
You are right of course.
But still of 1.5.x has a bugfix for the fluent converter for files from windows.
best regards
christian
Old   January 15, 2009, 01:49
Default hi everyone i am new to
NAVEEN.K.M
naveen is on a distinguished road
hi everyone
i am new to openfoam and i used to import gambitmsh to foam but i am not able to convert it into openfoam 1.4.1....could u please send me how to import gambitmsh(ascii format) to foam..
naveen is offline   Reply With Quote
Old   January 15, 2009, 03:30
Default Hi Naveen, In v1.4.1 you ne
Gijsbert Wierink
gwierink is on a distinguished road
Hi Naveen,
In v1.4.1 you need be outside your case directory, e.g. in your run directory where the case is located. The format is then
gambitToFoam <root> <casename> <meshfile> <scale>
In this format <root> is just a dot ("."), e.g. for a case called "cavity" with mesh file "cavity.msh" (located in your cavity case file), built in Gambit in millimeters, type:
gambitToFoam . cavity ./cavity/cavity.msh -scale 0.001
Rgds, Gijs
Regards, Gijs
gwierink is offline   Reply With Quote
Old   January 15, 2009, 03:34
Default Of course you might also use f
Gijsbert Wierink
Of course you might also use fluentMeshToFoam, depending on the solver type you chose in Gambit when building the mesh ...
Regards, Gijs
Old   January 15, 2009, 05:03
Default Hi Naveen, Hmm, that's a na
  #11
Gijsbert Wierink
Hi Naveen,
Hmm, that's a nasty one. I read that more people have problems with it (in OF-1.5) and that 1.5-dev has bug fixes for it, as written in this thread: http://www.cfd-online.com/cgi-bin/Op...126&post=29311. Do you have possibility to install OpenFOAM-1.5-dev?
And another thing, are you the mesh file is in the right format? Did you try using the Fluent 5/6 solver in gambit, save the mesh, and then export it with fluentMeshToFoam?
Rgds, Gijsbert
Regards, Gijs
Old   January 16, 2009, 04:45
Default hi Gijsbert sir i am
  #12
NAVEEN.K.M
hi Gijsbert sir
i am new to openfoam 1.4.1...i did naca 0012 airfoil case in fluent and now i used fluentMeshToFoam in openfoam 1.4.1...even though i followed your procedure to convert it into openfoam but i am getting error message....could u please solve this problem...
Old   January 16, 2009, 07:19
Default It seems to me that your mesh
  #13
Gijsbert Wierink
It seems to me that your mesh is not good (but this is just a guess). I would build a very simple mesh in Gambit (like a square box or something) and try to export that to OpenFOAM. This way you may find out if it's a mesh related or openFOAM related issue. Also, read this post on defect meshes: http://www.cfd-online.com/OpenFOAM_D...es/1/3443.html. With the content of the error message I can't help you, would need more specific one.
Regards, Gijs
Old   February 2, 2009, 04:01
Default Hi freinds can any he
  #14
venkateshtl
Hi freinds
can any help me to convert fluentMeshtoFoam i am finding some difficulty
Old   February 2, 2009, 04:14
  #15
venkateshtl
Hi freinds
Old   February 2, 2009, 05:46
Default Hi Venkatesh, Can you speci
  #16
Gijsbert Wierink
Hi Venkatesh,
Can you specify your problem? What is the error message, for example?
Rgds, Gijsbert
Regards, Gijs
Old   February 2, 2009, 05:57
Default Gijsbert Wierink sir
  #17
venkateshtl
my problem is that i hav done the naca 0012 airfoil case in gambit and i solved in fluent 6.3 ...now i want to compare these results in openfoam 1.4.1..now i need to import to fluentMeshTofoam in openfoam 1.4.1...can u tell me the procedure how to import the (.msh) file to openfoam 1.4.1..for example i used this format for conversion(my case name is-naca0012.msh) fluentMeshToFoam . naca0012 ./naca0012/naca0012.msh -scale 0.001...please send me the procedure of conversion..
Old   February 2, 2009, 06:09
Default Hi Venkatesh, The command y
  #18
Gijsbert Wierink
Hi Venkatesh,
The command you use seems the right one. Do you get an error message? And what does it say? Also, where do you run the command, i.e. are you in the right path? You need to run the command when you are in the path where the case file is located.
Rgds, Gijsbert
Regards, Gijs
Old   February 4, 2009, 01:59
Default hi Christian Winkler sir
  #19
NAVEEN.K.M
I have tried to load my fluent case into linux version and rewritten it as ascii, but it doesn't work! Maybe I need to try to solve it in openfoam 1.4.1 ..could u please help me how to import to openfoam using fluentMeshTofoam..
Old   February 4, 2009, 02:49
Default Hello Naveen, W
  #20
Maruthamuthu Venkatraman
maruthamuthu_venkatraman is on a distinguished road
Hello Naveen,
While writing the case file in Fluent remember to uncheck the Binary Opitions ...
This works well in OpenFoam 1.5 version. It wroked well for me sofar in simple geomtery cases..
Try this option. May be it works in 1.4 version aswell...
Regards
maruthamuthu_venkatraman is offline   Reply With Quote
