[Commercial meshers] Fluent3DMeshtoFoam
Old   September 25, 2007, 05:32
Default Fluent3DMeshtoFoam
Radu Mustata
r2d2 is on a distinguished road
Hi ,
My question is about the fact that the newly implemented fluent3DMeshToFoam does not write sets anymore. I need that in order to set some properties to sets with the setFieldByCellSet...
I see that it writes out cellZones, though. What is the difference between a cellZone and a cellSet and what would be the correct syntax for setting a value of some (scalar) field on that cellZone? I mean, to do the same thing as in setFieldsByCellSet.
Thanx,
Radu
r2d2 is offline   Reply With Quote
Old   September 25, 2007, 05:38
Default I had the same problem with th
Frank Bos
lr103476 is on a distinguished road
I had the same problem with the fluentMeshToFoam utility. I just compiled the old utility using the new OF-1.4.1.....now it writes sets again....
Regards, Frank
Frank Bos
lr103476 is offline   Reply With Quote
Old   September 25, 2007, 13:50
Default You can fairly easily convert
Mattijs Janssens
mattijs is on a distinguished road
You can fairly easily convert a zone to a set and vice versa.
setsToZones will convert sets to zones.
cellSet with 'zoneToCell' converts a cellZone into a cellSet
mattijs is offline   Reply With Quote
Old   September 26, 2007, 03:46
Default Thank you Mattijs for your sug
Radu Mustata
Thank you Mattijs for your suggestions. Will look into it.
Cheers,
Radu
Old   February 7, 2008, 04:35
Default Can anyone explain what is the
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
Can anyone explain what is the conceptual difference between cellSets and cellZones? Why are they both necessary?
Dragos
dmoroian is offline   Reply With Quote
Old   February 7, 2008, 04:47
Default I might not be the most approp
Radu Mustata
I might not be the most appropriate person to answer the first part but for the second question, I guess that one does not need them both. Unless you want to use some "old" tools like the aforementioned setFiedlbyCellSet or foamToVTK that does not use Zones (or it did not use zones when I used it) but Sets.
Radu
Old   February 7, 2008, 05:08
Default The difference is historical i
Eugene de Villiers
eugene is on a distinguished road
The difference is historical in origin and maintained due to inertia. Ideally there should be only one very flexible element grouping construct.
Zones are supported by mesh topo change engines, sets are not. As Radu mentioned, sets are older and used in many utilities including cellSet, pointSet, faceSet, setSet, foamToVTK and a few more.
eugene is offline   Reply With Quote
Old   February 7, 2008, 05:26
Default Thanks both of you for the exp
dmoroian's Avatar
Dragos
Thanks both of you for the explanations. Can you add something about regions? Are they different from zones or sets?
Dragos
Old   February 7, 2008, 06:51
Default Regions are the seeds of a mul
Eugene de Villiers
Regions are the seeds of a multi-mesh system. They don't do much at present.
Old   March 12, 2008, 18:31
Default Hi , The fluent3DMeshToFoam
Danielle PRL
danielle is on a distinguished road
Hi ,
The fluent3DMeshToFoam does not write faceZones. I need that in order to use the MRF (impeller and zone MRF).
How can I get the faceZones?
Thanks a lot.
danielle is offline   Reply With Quote
Old   March 13, 2008, 03:29
Default Hi, Danielle, You need first
  #11
Paul Mauk
plmauk is on a distinguished road
Hi, Danielle,
You need first faceSets, using faceSets you can
make faceZones (setsToZones).
Paul.
plmauk is offline   Reply With Quote
Old   March 14, 2008, 11:38
Default Thank you for your answer Paul
  #12
Danielle PRL
Thank you for your answer Paul,
I have tree zones. and I should have the zone_MRF in faceCells.
I make this steps:
1) flunet3DMeshToFoam . case3dMRF
2) in faceSetDict I make the name of zone zone_MRF and action new
3) faceSet . Test_zones
4) to create zone_MRFCells file I make in cellSetDict
name zone_MRFCells;
action new;
zoneToCell
name zone_MRF;
5) cellSet . Test_zones
6)setsToZones . Test_zones
My first question is:
is that the right commandes to have a corresponding face of my zone_MRF is faceCells file ?
my second is:
what is the roole of flipMap?
I make -noFlipMap like option
Thank you for your precious help!
Old   March 14, 2008, 15:58
Default Hi, the steps are exactly:
  #13
Rachid bannari
bannari is on a distinguished road
1) fluent3DMeshToFoam .. yourCase file.msh (you are in the folder yourCase)
2)copy the file cellSetDict from the case mixerVessel2D of MRFSimpleFoam to system of your case.
3)cellSet .. yourCase
4) copy the file faceSetDict_rotorFaces from the case mixerVessel2D of MRFSimpleFoam to system/faceSetDict of your case.
5)faceSet .. yourCase
6)copy the file faceSetDict_noBoundaryFaces from the case mixerVessel2D of MRFSimpleFoam to system/faceSetDict of your case.
7)faceSet .. yourCase
8)setsToZones .. yourCase -noFlipMap
Good luck
Rachid
bannari is offline   Reply With Quote
Old   March 27, 2008, 04:01
Default dear everyone, when i do the s
  #14
wayne.zhang
waynezw0618 is on a distinguished road
Send a message via MSN to waynezw0618 Send a message via Skype™ to waynezw0618
dear everyone, when i do the step 1) as BANNARI ,i can not get the mesh .for the error message is :
-->FOAM FATAL ERROR : Do not understan characters:
from function fluentMeshToFoam::lexer
in file FluentMeshToFoam.L at line 703
how can i resolve it?
waynezw0618 is offline   Reply With Quote
Old   March 27, 2008, 04:18
Default You must have some unrecognise
  #15
Radu Mustata
You must have some unrecognised character in the .msh file. Check fluentMeshToFoam.L to see what is accepted and what not.
Radu
Old   March 27, 2008, 05:31
Default Typpically this occurs when th
  #16
caw
Christian Winkler
caw is on a distinguished road
Typpically this occurs when the mesh was exported from a gambit running under windows.
Therefore: do a dos2unix on the mesh file before converting it with fluent3dmeshtofoam
caw is offline   Reply With Quote
Old   March 28, 2008, 00:47
Default Thanks a lot i resolve it by
  #17
wayne.zhang
Thanks a lot i resolve it by do a dos2unix
but when i finished all steps accordig to Rachid,and running my case there is FATAL EEROR!
cannot find MRFzone cellzone ,what is the problem?
thanks!
wayne
Old   March 28, 2008, 00:51
Default i think it may be caused by th
  #18
wayne.zhang
i think it may be caused by the name "rotor" in the MRFsimplefoam tut.,for too much name "rotor",cellzone name is "rotor",boundary name also "rotor",set name still "rotor",could you please give me more about that tut?
Old   March 29, 2008, 08:18
Default Hi my case is running now,bu
  #19
wayne.zhang
Hi
my case is running now,but i am not quiet sure it is right,for just modify the cellzone name and some boudary name.i do not clearly understand the procedure of cellSet and faceSet.
1why should do faceset and cellset?
2what is the meannig of the both?
3when do these what changes?
4what is setTozone
Old   March 29, 2008, 10:36
Default by the way: 5 when i just wan
  #20
wayne.zhang
by the way:
5 when i just want to simulate the a rotated zone like impeller without interaction with station zone do i still need to do cellSet and faceSet?
6 in object MRFZones the definition of omega omega omega [0 0 -1 0 0 0 0] ,does that mean the dimension is revolution per second? or rad/s?
wayne
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) Aadhavan OpenFOAM Meshing & Mesh Conversion 2 March 8, 2018 01:47
periodic (cyclic) boundary - fluent3DMeshToFoam cyln OpenFOAM 1 October 17, 2017 02:59
[Commercial meshers] fluent3DMeshToFoam conversion problem CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 14 March 12, 2014 05:16
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 09:28
OpenFOAM command from inside MATLAB sega OpenFOAM Post-Processing 18 September 25, 2012 07:35
