[Commercial meshers] FluentMeshToFoam hangs with no error |
November 26, 2006, 15:22 |
I generated a hex grid for a free-surface-piercing NACA 0024 using Gridgen from Pointwise, Inc. It is a simple c-type grid with clustering near the wall (for wall fxn) and near the waterplane. However, when I try to convert it, it simply hangs and does not report an error. Any suggestions on how to debug this?
Here is the output: Exec : fluentMeshToFoam . SPNACA SPNACA/spnaca24_sublayer.cas Date : Nov 26 2006 Time : 15:19:30 Host : ritchie.aset.psu.edu PID : 4877 Root : /scratch/egp11 Case : SPNACA Nprocs : 1 Create time Reading header: "exported from Gridgen 15.09R3" Dimension of grid: 3 Number of points: 345321 number of faces: 1005100 Number of cells: 330000 Reading points Reading uniform cells Reading zone data Embedded blocks in comment or unknown Found end of section in unknown ,Reading uniform faces FINISHED LEXING dimension of grid: 3 Creating shapes for 3-D cells ----------this is where it hangs--------------- thanks, Eric Paterson |
November 26, 2006, 15:40 |
By the way, my Fluent case fil
By the way, my Fluent case file was written as ASCII, and I deleted the DOS control characters using dos2unix (unfortunately, my desktop machine is a Dell).
November 26, 2006, 16:08 |
This is a strange place for th
Hrvoje Jasak
Rep Power: 33 |
This is a strange place for the converter to hang: you have successfully finished lexing. Can I have a look at this file if it's not confidential?
Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
November 26, 2006, 17:07 |
Hrv,
You can download the f
Hrv,
You can download the file from: http://idisk.mac.com/egpaterson-Public It is the only file there. Also, I mistyped my original email. This grid was designed for sublayer resolution. Eric |
November 27, 2006, 04:55 |
I get a nice core dump over he
Hrvoje Jasak
Rep Power: 33 |
I get a nice core dump over here:
--> FOAM FATAL ERROR : index 6 out of range 0 ... 5 It turns out that the cell number 182, defined as a hex, has got 7 (at least 7?) faces, which is wrong. The offending face index is 976015. My guess is that you have defined a face of cell 182 to belong to two boundary patches at the same time. As usual, nothing wrong with my converter. Hrv
November 27, 2006, 06:28 |
Thanks for the debug, Hrv. I'
Thanks for the debug, Hrv. I'll double-check, but this would be impossible to explicitly do when using GridGen. Maybe there is a bug with the Gridgen -> Fluent converter, although I've not run into one before. I'll post back when I find the error.
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 13:21 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
Errors in UDF | shashank312 | Fluent UDF and Scheme Programming | 6 | May 30, 2013 20:30 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 17:38 |
