[Commercial meshers] FluentMeshToFoam and Grid Interfaces
Old   May 9, 2006, 08:49
Default FluentMeshToFoam and Grid Interfaces
Francesco Del Citto
fra76 is on a distinguished road
Hi!
I have a mesh made with tgrid (a .msh file), with a lot of interior faces that are walls and a boundary layer over some surfaces.
I've successfully splitted interior surfaces with splitMeshWithSets by Bernhard Gschaider.
I've a problem with the side of the prismatic boundary layer.
In fluent, the same mesh is solved defining a "Grid interface" between the patch with rectangles of the boundary layer extrusion (prism-side-8) and a patch containing a triangular remeshing of the same surface (prism-side-8-retri-31), mad in order to have a fulle tetrahedric mesh of the volume.
I.e., I have two coinciding patches with different surface meshes.
Is it possible to threat such a situation?
I've read in the user guide, in the section related to fluentMeshToFoam: "There is currently no support for embedded interfaces and refinement trees.". I'm afraid this is a "No" to my question, but I hope I'm wrong...
Francesco
fra76 is offline   Reply With Quote
Problem with grid convergence for turbulent flow around cylinder aakie OpenFOAM Running, Solving & CFD 3 November 13, 2018 04:39
[Commercial meshers] Converting an abaqus mesh using matlab scripts and fluentMeshToFoam MichaelD OpenFOAM Meshing & Mesh Conversion 1 July 2, 2014 06:34
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 10:52
[Commercial meshers] FluentMeshToFoam CRT OpenFOAM Meshing & Mesh Conversion 3 May 24, 2012 16:07
[Commercial meshers] FluentMeshToFoam hangs with no error egp OpenFOAM Meshing & Mesh Conversion 5 November 27, 2006 06:28
