[blockMesh] Truly 3D Mesh
Old   July 22, 2008, 14:39
Default Truly 3D Mesh
Trevor Sherk
tsherk86 is on a distinguished road
I've been working on creating a mesh for a cylindrical annulus, but have had no luck finding out how to extends the mesh points INSIDE the annulus so that there are grid points to solve the solution inside the cylinder rather than just on the outside. I can't seem to find out how to do this anywhere. Am I missing something? OpenFOAM wouldn't solve all the way through the cylinder if I only had grid points on the exteriors of the annulus would it? i.e., I believe the fluid flow would appear the same the entire way through the cylinder along the z direction as I have no mesh on the inside connecting the boundaries.
Thanks for your help!
-Trevor
tsherk86 is offline   Reply With Quote
Old   July 22, 2008, 15:58
Default Here is a picture of my mesh s
Trevor Sherk
Here is a picture of my mesh so far
Old   July 22, 2008, 16:07
Default And here is my blockMesh file:
Trevor Sherk
blockMeshDict
Old   July 23, 2008, 02:57
Default I Trevor, just small questi
Cedric DUPRAT
cedric_duprat is on a distinguished road
I Trevor,
just small questions, what do you want to do ?
- solve Navier-Stokes equation inside the "internal"pipe ? (but no mesh ...)
- solve Navier-Stokes inside the annulus part ?
well, where is your fluid, ect ...
Can you tell me a little bit more just for me to help you (if I can) because, if you need to solve a cylindrical annulus, I don't understand why you need solution in the internal pipe ...
Cedric
cedric_duprat is offline   Reply With Quote
Old   July 23, 2008, 06:47
Default To make a cylinder, you need 1
Eugene de Villiers
eugene is on a distinguished road
To make a cylinder, you need 12 blocks. 4 for the core region and 8 around the outside.
When joined together, the 4 core blocks will expose 8 facets in the radial direction. Seen end on, you will distort them to look like an octagon. To each of these 8 facets you then attach one of the 8 outer blocks to interface with the outer cylinder.
eugene is offline   Reply With Quote
Old   July 23, 2008, 08:44
Default Hello Cedric, The fluid is
Trevor Sherk
Hello Cedric,
The fluid is inside the annulus, so between the inner wall and the outer wall. I wish to solve Navier-Stokes inside the annulus part which is empty of mesh points. My understanding of simulation and modeling is that when solving these equations, the solution is iterated over the mesh points. Therefore, to model the fluid inside the annulus I must have grid points inside the annulus and not just on the walls. Is this correct? If so, I am wondering how to connect the inner and outer walls with a grid inside the annulus.
The problem is the differentially heated rotating annulus problem. Perhaps you've heard of this classic experiment.
Thanks!
-Trevor
Old   July 23, 2008, 10:46
Default Hi, Trevor, It does look li
Pei-Ying Hsieh
hsieh is on a distinguished road
Hi, Trevor,
It does look like you have grid points inside domain you are interested. I run your blockMeshDict and plotted the mesh and a clip of the mesh.
Pei
hsieh is offline   Reply With Quote
Old   July 23, 2008, 10:52
Pei-Ying Hsieh
Hi, Trevor,
Pei
Old   July 23, 2008, 11:03
Default Hi trevor, As pei show us,
Cedric DUPRAT
Hi trevor,
As pei show us, it seems that you aldready have some points inside the annulus region.
These points correspond to the line :
hex (0 1 2 3 16 17 18 19) (10 10 10) simpleGrading (1 1 1)
of the blockMeshDict.
For exemple here, the (10 10 10) is the number of points in each direction (x, y z) for the first block.
The same for the other.
If you are still not sure (I hope you are now) you can still do a checkMesh of your case and you should see the number of nodes, cells, ect ... of your geometry
Old   July 23, 2008, 12:43
Default Sorry, I'm not convinced still
Trevor Sherk
Sorry, I'm not convinced still. Paraview must fill in those lines so that it appears to have mesh points inside. I have done the clip filter with a simple box too and it shows the same effect - making it appear to have grid points all the way through, but they don't. Try doing the clip filter at, say, a 45 degree angle and you will see what I mean. Those lines you see in Pei's picture are created by ParaView for some reason.
Thanks,
Trevor
Old   July 23, 2008, 15:31
Default Hi, Trevor, OK, this is a c
  #11
Pei-Ying Hsieh
Hi, Trevor,
OK, this is a cut out of the original mesh. It will hard to believe that there are no nodes inside the domain.
Pei
Old   July 23, 2008, 15:39
Default Hi, Trevor, Forgot to menti
  #12
Pei-Ying Hsieh
Hi, Trevor,
Forgot to mention this:
Look in constant/polyMesh/Points file, it lists 9680 points. This is 11*11*80 - matches the number of points you specified.
Pei
Old   July 23, 2008, 16:54
Default Hello Pei, Well, after seei
  #13
Trevor Sherk
Hello Pei,
Well, after seeing that picture I now believe you are right. Thanks! I will now try my simulation.
I just assumed the points weren't inside because of Paraview actually. When I would look at the mesh in Paraview and zoom inside, there was no inside grid. Also, when I would run the tutorial cases, the fluid flow would appear the same through all slices of the geometry. I guess they must not have been intended to be 3D cases. This is great! I hope you are right.
Thank you very much for your time and assistance.
-Trevor
Old   July 24, 2008, 02:48
Default Hi Trevor and Pei "I hope y
  #14
Cedric DUPRAT
Hi Trevor and Pei
"I hope you are right" .... no doubt, we are :o)
Pei, nice picture the last one, I'm really curious to know how you managed to get that with paraView ?
Did you decompose the mesh for parallel run and it correspond to one processor mesh ?
Thanks,
Cedric
Old   July 24, 2008, 07:43
Default Hi, Cedic, In paraview 3.2.
  #15
Pei-Ying Hsieh
Hi, Cedic,
In paraview 3.2.1,
1. click "Edit", select "Select Cells Through"
2. select the area of mesh you are interested using the mouse.
3. Click "Filter", then, "Alphabetical", then, select "Extract Selection".
4. click "Copy Active Selection".
5. click "Apply"
6. click "Display"
7. under "Style", select "Surface With Edges" under Representation.
Pei
PS: hope I did not miss anything.
Old   July 25, 2008, 03:31
Default Hi Pei, Thank you, I'll try
  #16
Cedric DUPRAT
Hi Pei,
Thank you, I'll try with the old version of paraView first.
And maybe with the new one in a couple of weeks.
Cedric
Old   July 31, 2008, 17:28
Default Hello again! I am having some
  #17
Trevor Sherk
Hello again!
I am having some trouble inputting the equations for the model into OpenFOAM. Specifically, for dU/dt (U is the vector fluid velocity), I need to calculate r, the radius ((x^2+y^2)^(1/2)), and the cylindrical unit vector r, i_r, which, when expressed in terms of cartesian coordintes, I THINK is cos(arctan(y/x))*i_x + sin(arctan(y/x))*i_y, where x and y are the usual cartesian coordinates.
I think I can use mag(U) to calculate r (?), but from my reading I believe OpenFOAM treats tensors as a unit, and does not look at individual components, such as x and y... anyhow, I am not sure how to do handle finding x and y. I tried U.component(0) and U. component(1) for x and y, and get a floating point exception. So I gather my other problem is that U.y is sometimes 0...
Any suggestions would be greatly appreciated!!
Thanks,
Trevor
Old   August 1, 2008, 09:57
Default Never mind! I think I figured
  #18
Trevor Sherk
Never mind! I think I figured out another way to do the problem.
Old   September 15, 2010, 11:50
T.D. is on a distinguished road
Hi Guys, i am new in openfoam, my question is that: if i want to the solve the navier stokes eqns in cylindrical coordinates, i must just define my coordinates system to cylindrical one (r, theta,z)? if so, what about the operators like "laplacian","divergence", for example: div(phi), they will be automatically used in cylindrical coordinates? or we must write new definitions for them in cylind. coord.?
thanks a lot
T.D. is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 11:14
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 08:52
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
