[blockMesh] error message with modeling a cube with a hold at the center |
March 13, 2012, 19:44 |
Hsingtzu Wu
Rep Power: 15 |
my blockMeshDict code was like
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.01; vertices ( (0.45 0 0) //21 (0.5 0 0) (0.63 0 0) (0.63 0.353553391 0) (0.63 0.63 0) (0.353553391 0.63 0) (0.353553391 0.353553391 0) (0.318198052 0.318198052 0) (0 0.45 0) (0 0.5 0) (0 0.63 0) (-0.353553391 0.63 0) (-0.63 0.63 0) (-0.63 0.353553391 0) (-0.353553391 0.353553391 0) (-0.318198052 0.318198052 0) (-0.45 0 0) (-0.5 0 0) (-0.63 0 0) (-0.63 -0.353553391 0) (-0.63 -0.63 0) (-0.353553391 -0.63 0) (-0.353553391 -0.353553391 0) (-0.318198052 -0.318198052 0) (0 -0.45 0) (0 -0.5 0) (0 -0.63 0) (0.353553391 -0.63 0) (0.63 -0.63 0) (0.63 -0.353553391 0) (0.353553391 -0.353553391 0) (0.318198052 -0.318198052 0) (0.45 0 0.98) (0.5 0 0.98) (0.63 0 0.98) (0.63 0.353553391 0.98) (0.63 0.63 0.98) (0.353553391 0.63 0.98) (0.353553391 0.353553391 0.98) (0.318198052 0.318198052 0.98) (0 0.45 0.98) (0 0.5 0.98) (0 0.63 0.98) (-0.353553391 0.63 0.98) (-0.63 0.63 0.98) (-0.63 0.353553391 0.98) (-0.353553391 0.353553391 0.98) (-0.318198052 0.318198052 0.98) (-0.45 0 0.98) (-0.5 0 0.98) (-0.63 0 0.98) (-0.63 -0.353553391 0.98) (-0.63 -0.63 0.98) (-0.353553391 -0.63 0.98) (-0.353553391 -0.353553391 0.98) (-0.318198052 -0.318198052 0.98) (0 -0.45 0.98) (0 -0.5 0.98) (0 -0.63 0.98) (0.353553391 -0.63 0.98) (0.63 -0.63 0.98) (0.63 -0.353553391 0.98) (0.353553391 -0.353553391 0.98) (0.318198052 -0.318198052 0.98) ); blocks ( hex (31 30 25 24 63 62 57 56) (10 10 5) simpleGrading (1 1 1) hex (0 1 30 31 32 33 62 63) (10 10 5) simpleGrading (1 1 1) hex (7 6 1 0 39 38 33 32) (10 10 5) simpleGrading (1 1 1) hex (8 9 6 7 40 41 38 39) (10 10 5) simpleGrading (1 1 1) hex (14 15 8 9 46 47 40 41) (10 10 5) simpleGrading (1 1 1) hex (17 16 15 14 49 48 47 46) (10 10 5) simpleGrading (1 1 1) hex (22 23 16 17 54 55 48 49) (10 10 5) simpleGrading (1 1 1) hex (25 24 23 22 57 56 55 54) (10 10 5) simpleGrading (1 1 1) hex (25 26 27 30 57 58 59 62) (10 10 5) simpleGrading (1 1 1) hex (27 28 29 30 59 60 61 62) (10 10 5) simpleGrading (1 1 1) hex (29 30 1 2 61 62 33 34) (10 10 5) simpleGrading (1 1 1) hex (1 2 3 6 33 34 35 38) (10 10 5) simpleGrading (1 1 1) hex (3 4 5 6 35 36 37 38) (10 10 5) simpleGrading (1 1 1) hex (5 6 9 10 37 38 41 42) (10 10 5) simpleGrading (1 1 1) hex (9 10 11 14 41 42 43 46) (10 10 5) simpleGrading (1 1 1) hex (11 12 13 14 43 44 45 46) (10 10 5) simpleGrading (1 1 1) hex (13 14 17 18 45 46 49 50) (10 10 5) simpleGrading (1 1 1) hex (17 18 19 22 49 50 51 54) (10 10 5) simpleGrading (1 1 1) hex (19 20 21 22 51 52 53 54) (10 10 5) simpleGrading (1 1 1) hex (21 22 25 26 53 54 57 58) (10 10 5) simpleGrading (1 1 1) ); edges ( arc 0 7 (0.4 0.2062 0) //114 arc 7 8 (0.2062 0.4 0) arc 8 15 (-0.2062 0.4 0) arc 15 16 (-0.4 0.2062 0) arc 16 23 (-0.4 -0.2062 0) arc 23 24 (-0.2062 -0.4 0) arc 24 31 (0.2062 -0.4 0) arc 31 0 (0.4 -0.2062 0) arc 32 39 (0.4 0.2062 0.98) arc 39 40 (0.2062 0.4 0.98) arc 40 47 (-0.2062 0.4 0.98) arc 47 48 (-0.4 0.2062 0.98) arc 48 55 (-0.4 -0.2062 0.98) arc 55 56 (-0.2062 -0.4 0.98) arc 56 63 (0.2062 -0.4 0.98) arc 63 32 (0.4 -0.2062 0.98) arc 1 6 (0.4 0.3 0) arc 6 9 (0.3 0.4 0) arc 9 14 (-0.3 0.4 0) arc 14 17 (-0.4 0.3 0) arc 17 22 (-0.4 -0.3 0) arc 22 25 (-0.3 -0.4 0) arc 25 30 (0.3 -0.4 0) arc 30 1 (0.4 -0.3 0) arc 33 38 (0.4 0.3 0.98) arc 38 41 (0.3 0.4 0.98) arc 41 46 (-0.3 0.4 0.98) arc 46 49 (-0.4 0.3 0.98) arc 49 54 (-0.4 -0.3 0.98) arc 54 57 (-0.3 -0.4 0.98) arc 57 62 (0.3 -0.4 0.98) arc 62 33 (0.4 -0.3 0.98) ); boundary ( left { // type symmetryPlane; type cyclic; neighbourPatch right; faces ( (12 13 45 44) (13 18 50 45) (18 19 51 50) (19 20 52 51) ); } right { // type symmetryPlane; type cyclic; neighbourPatch left; faces ( (3 4 36 35) (3 2 34 35) (2 29 61 34) (29 28 60 61) ); } down { // type symmetryPlane; type cyclic; neighbourPatch up; faces ( (20 21 53 52) (21 26 58 53) (26 27 59 58) (27 28 60 59) ); } up { // type symmetryPlane; type cyclic; neighbourPatch down; faces ( (11 12 44 43) (11 10 42 43) (10 5 37 42) (4 5 37 36) ); } holeDownLeft { type patch; faces ( (16 23 55 48) (23 24 56 55) ); } holeDownRight { type patch; faces ( (24 31 63 56) (0 31 63 32) ); } holeUpLeft { type patch; faces ( (15 16 48 47) (8 15 47 40) ); } holeUpRight { type patch; faces ( (0 7 39 32) (7 8 40 39) ); } front { type patch; faces ( (24 25 30 31) (30 31 0 1) (0 1 6 7) (6 7 8 9) (8 9 14 15) (14 15 16 17) (16 17 22 23) (22 23 24 25) (25 26 27 30) (27 28 29 30) (29 30 1 2) (1 2 3 6) (3 4 5 6) (5 6 9 10) (9 10 11 14) (11 12 13 14) (13 14 17 18) (17 18 19 22) (19 20 21 22) (21 22 25 26) ); } back { type patch; faces ( (56 57 62 63) (62 63 32 33) (32 33 38 39) (38 39 40 41) (40 41 46 47) (46 47 48 49) (48 49 54 55) (54 55 56 57) (57 58 59 62) (59 60 61 62) (61 62 33 34) (33 34 35 38) (35 36 37 38) (37 38 41 42) (41 42 43 46) (43 44 45 46) (45 46 49 50) (49 50 51 54) (51 52 53 54) (53 54 57 58) ); } ); mergePatchPairs ( ); // ************************************************************************* // Code:
Creating block mesh topology --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.00259862 for face 0 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.00288735 for face 1 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.00274299 for face 2 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.00274299 for face 3 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.00274299 for face 4 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.00274299 for face 5 --> FOAM Warning : From function blockMesh::createTopology(IOdictionary&) in file blockMesh/blockMeshTopology.C at line 255 negative volume block : 0, probably defined inside-out --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.00259862 for face 0 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.00288735 for face 1 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.00274299 for face 2 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.00274299 for face 3 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.00274299 for face 4 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.00274299 for face 5 --> FOAM Warning : From function blockMesh::createTopology(IOdictionary&) in file blockMesh/blockMeshTopology.C at line 255 negative volume block : 1, probably defined inside-out --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.00259862 for face 0 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.00288735 for face 1 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.00274299 for face 2 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.00274299 for face 3 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.00274299 for face 4 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.00274299 for face 5 --> FOAM Warning : From function blockMesh::createTopology(IOdictionary&) in file blockMesh/blockMeshTopology.C at line 255 negative volume block : 2, probably defined inside-out --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.00259862 for face 0 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.00288735 for face 1 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.00274299 for face 2 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.00274299 for face 3 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.00274299 for face 4 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.00274299 for face 5 --> FOAM Warning : From function blockMesh::createTopology(IOdictionary&) in file blockMesh/blockMeshTopology.C at line 255 negative volume block : 3, probably defined inside-out --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.0117355 for face 0 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.0117355 for face 1 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.015964 for face 2 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.00750712 for face 3 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.0117355 for face 4 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.0117355 for face 5 --> FOAM Warning : From function blockMesh::createTopology(IOdictionary&) in file blockMesh/blockMeshTopology.C at line 255 negative volume block : 10, probably defined inside-out --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.0117355 for face 0 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.0117355 for face 1 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.015964 for face 2 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.00750712 for face 3 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.0117355 for face 4 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.0117355 for face 5 --> FOAM Warning : From function blockMesh::createTopology(IOdictionary&) in file blockMesh/blockMeshTopology.C at line 255 negative volume block : 13, probably defined inside-out --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.0117355 for face 0 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.0117355 for face 1 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.015964 for face 2 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.00750712 for face 3 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.0117355 for face 4 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.0117355 for face 5 --> FOAM Warning : From function blockMesh::createTopology(IOdictionary&) in file blockMesh/blockMeshTopology.C at line 255 negative volume block : 16, probably defined inside-out --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.0117355 for face 0 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.0117355 for face 1 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.015964 for face 2 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.00750712 for face 3 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.0117355 for face 4 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.0117355 for face 5 --> FOAM Warning : From function blockMesh::createTopology(IOdictionary&) in file blockMesh/blockMeshTopology.C at line 255 negative volume block : 19, probably defined inside-out Code:
--> FOAM FATAL ERROR: More than six unsigned transforms detected: 6(((0.0126 -0.00248802 0) (1 0 0 0 1 0 0 0 1) 0) ((0.0126 -0.00221157 0.00196) (1 0 0 0 1 0 0 0 1) 0) ((0.0126 -0.00193513 0.00392) (1 0 0 0 1 0 0 0 1) 0) ((0.0126 -0.00165868 0.00588) (1 0 0 0 1 0 0 0 1) 0) ((0.0126 -0.00138223 0.00784) (1 0 0 0 1 0 0 0 1) 0) ((0.0126 -0.00082934 0) (1 0 0 0 1 0 0 0 1) 0)) From function void Foam::globalIndexAndTransform::determineTransforms() in file primitives/globalIndexAndTransform/globalIndexAndTransform.C at line 185. FOAM exiting Hsingtzu |
Power placement question on a cube | Octagon1 | FloEFD, FloWorks & FloTHERM | 1 | December 24, 2016 01:30 |
Data Center Modeling | Aaron Chen | STAR-CCM+ | 0 | February 17, 2016 17:18 |
Center of a mesh cell | pyroknife | Main CFD Forum | 1 | July 10, 2015 05:25 |
Cooling cube in a room | John_Major | System Analysis | 0 | July 4, 2015 03:24 |
Gambit help: Cube inside cube | Jack Martinez | FLUENT | 13 | August 11, 2010 06:29 |
