[snappyHexMesh] sHM cannot find file
Like Tree2Likes
  • 2 Post By openfoam_user
Old   March 4, 2010, 01:40
Default sHM cannot find file
Dustin
nitsud is on a distinguished road
Hey all,
I'm trying to run snappy in parallel and keep getting the error:
[0]
[0]
[0] Cannot find file "" in directory "constant/triSurface"
[0]
[0]     From function Time::findInstance(const fileName&, const word&, const IOobject::readOption)
[0]     in file db/Time/findInstance.C at line 148.
[0]
The case works on a single core, but barfs on a multicore job. Hoping that someone has seen this before!!
Thanks,
Dustin
nitsud is offline   Reply With Quote
Old   March 8, 2010, 07:08
Patrick Wang
foam_noob is on a distinguished road
Hi Dustin,
after you run decomposePar. You have copy the triSurface folder into every constant folder of every processor folder (processor0, processor1...)
Snappy should run afterwards.
Patrick
foam_noob is offline   Reply With Quote
Old   March 14, 2010, 01:01
Dustin
Thanks Patrick, that got it to run, but it's now failing on reconstructPar, again complaining about a missing file:
cannot open file
file: caseRoot/processor0/1/polyMesh/pointProcAddressing at line 0.
    From function regIOobject::readStream()
    in file db/regIOobject/regIOobjectRead.C at line 62.
FOAM exiting
Looked at each of the processors with paraFoam and each looked as expected.
Thanks,
Dustin
Old   March 15, 2010, 02:08
Patrick Wang
Hey,
I've never had that problem when I worked with decomposePar so I have no idea what the problem might be. It's best if you search the forum.
Sorry that I couldn't be of more help.
Old   March 15, 2010, 04:09
Simon Rees
sjrees is on a distinguished road
I have managed to get SHM working in parallel and can offer a couple of comments.
i. You can just make soft links to your stl file in the processor directories rather than copying it lots of times.
ii. When doing the reconstruction after running SHM I found it necessary to use the -constant option to rebuild the mesh. I also found it necessary to increase the write tolerance to 10^-8 when using reconstructParMesh.
sjrees is offline   Reply With Quote
Old   July 14, 2010, 04:08
stephane sanchi
openfoam_user is on a distinguished road
hello,
I am trying to run sHM in parallel.
When I run :
snappyHexMesh -parallel
I get the following error message
[250]cfs10-sanchi /shared/sanchi/OpenFOAM/sanchi-1.7.x/pippo % snappyHexMesh -parallel 12
--> FOAM FATAL ERROR:
bool Pstream::init(int& argc, char**& argv) : attempt to run parallel on 1 processor
From function Pstream::init(int& argc, char**& argv)
in file Pstream.C at line 73.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) in "/shared/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/shared/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 Foam::Pstream::init(int&, char**&) in "/shared/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/openmpi-1.4.1/libPstream.so"
#3 Foam::argList::argList(int&, char**&, bool, bool) in "/shared/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#4 main in "/shared/OpenFOAM/OpenFOAM-1.7.x/applications/bin/linux64GccDPOpt/snappyHexMesh"
#5 __libc_start_main in "/lib64/libc.so.6"
#6 _start at /usr/src/packages/BUILD/glibc-2.10.1/csu/../sysdeps/x86_64/elf/start.S:116
[cfs10:09124] *** Process received signal ***
[cfs10:09124] Signal: Aborted (6)
[cfs10:09124] Signal code: (-6)
[cfs10:09124] [ 0] /lib64/libc.so.6 [0x2af77d069560]
[cfs10:09124] [ 1] /lib64/libc.so.6(gsignal+0x35) [0x2af77d0694e5]
[cfs10:09124] [ 2] /lib64/libc.so.6(abort+0x180) [0x2af77d06a9b0]
[cfs10:09124] [ 3] /shared/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libOpenFOAM.so(_ZN4Foam5error5abortEv+0x241) [0x2af77c16f7f1]
[cfs10:09124] [ 4] /shared/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/openmpi-1.4.1/libPstream.so(_ZN4Foam7Pstream4initERiRPPc+0x2a6) [0x2af77d398b96]
[cfs10:09124] [ 5] /shared/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libOpenFOAM.so(_ZN4Foam7argListC1ERiRPPcbb+0x2869) [0x2af77c17ec49]
[cfs10:09124] [ 6] snappyHexMesh [0x40515a]
[cfs10:09124] [ 7] /lib64/libc.so.6(__libc_start_main+0xfd) [0x2af77d055a7d]
[cfs10:09124] [ 8] snappyHexMesh [0x404639]
[cfs10:09124] *** End of error message ***
Abort
Any idea ?
Stephane.
openfoam_user is offline   Reply With Quote
Old   July 20, 2010, 09:04
stephane sanchi
I have found the solution reading the advices of W. Heydlauff. You don't need to copy the stl file into each processor* folder.
Hereafter isthe procedure.
- run "blockMesh" a usual
- decomposeMethode in decomposeParDict must be hirarcial
- run "decomposePar"
- run "foamJob -p -s snappyHexMesh"
- afterwards run "reconstructParMesh -mergeTol 1e-06 -latestTime"
(or -time 1; -time 2; ...)
Works perfect for the 3 steps of sHM:
castellatedMesh true;
snap true;
addLayers true;
Stephane.
shipman and arsenis like this.
Old   January 9, 2019, 08:29
Xutong
zhxutong is on a distinguished road
Actually it is not necessary to copy triSurface folder into every processor folder since it will read from the main constant folder anyway. I met a similar "cannot find file" problem. In my case, it was .eMesh file missing. So it was solved by just run "surfaceFeatureExtract"
zhxutong is offline   Reply With Quote
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 18:13
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 17:34
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 12:41
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 10:57
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 11:46
