[snappyHexMesh] multi-Region failed to split one of the regions
Old   April 23, 2010, 11:34
Default multi-Region failed to split one of the regions
Pei-Ying Hsieh
phsieh2005 is on a distinguished road
I have several solid parts. SnappyHexMesh meshed with the correct refinement level for all regions, but, one of the solid regions did not get split from the base mesh. I am wondering if anyone experienced something like this and has a solution for it?
Thanks!
Pei
phsieh2005 is offline   Reply With Quote
Old   April 26, 2010, 07:26
suitup is on a distinguished road
Hi, check your blockMesh in paraview and load additional your stl cad files into it.
If a boundary of a blockmesh cell is too near to one of your cad boundaries, snappyhexmesh can't mesh it correctly and problems can occur.
You have to change your blockMesh segmentation or the possition of your cad file.
Maybe it helps, good luck.
suitup is offline   Reply With Quote
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel U.Golling OpenFOAM Running, Solving & CFD 52 September 23, 2023 03:35
[snappyHexMesh] Multi Region Mesh of a car filter Zephiro88 OpenFOAM Meshing & Mesh Conversion 3 September 11, 2019 19:34
p_rgh initial residual no change with different settings manuc OpenFOAM Running, Solving & CFD 3 June 26, 2018 15:53
Some questions about a multi region case run in parallel zfaraday OpenFOAM Running, Solving & CFD 5 February 23, 2017 10:25
[Other] mesh interface for multi region Mohammad Jam OpenFOAM Meshing & Mesh Conversion 3 December 5, 2016 07:23
