[snappyHexMesh] SnappyHexMesh..
Old   October 27, 2010, 11:27
Default SnappyHexMesh..
Samuele Z
samiam1000 is on a distinguished road
Dear All,
I have a question: is it possible to generate a volume mesh inside a certain surface?
I mean, I have a non-simple stl geometry (the reconstruction of nasal cavity) and I wanna mesh the inside volume.
If my file is called nasal_cavity.stl, how can I set a good snappyHexMeshDict file in order to generate my mesh inside the surface??
It is a closed surface. The only problem is that is presents some loops. I hope this is not a problem.
Here is my snappyHexMeshDict file:
geometry
      nasal_cavity.stl // STL filename
          type triSurfaceMesh;
      box  // User defined region name
          type   searchableBox;       // region defined by bounding box
          min    (-0.0422 -0.0880 -0.576);
          max    (-0.0338 0.00583 -0.479);
But it does not work. I get this:
samiam@penrose: ~/Desktop/naso_ok/test > snappyHexMesh snappyHexMeshDict
Usage: snappyHexMesh [-overwrite] [-parallel] [-case dir]  [-help] [-doc] [-srcDoc]
--> FOAM FATAL ERROR:
Wrong number of arguments, expected 0 found 1
FOAM exiting
samiam@penrose: ~/Desktop/naso_ok/test > blockMesh snappyHexMeshDict
Usage: blockMesh [-dict dictionary] [-case dir] [-blockTopology] [-region name]  [-help] [-doc] [-srcDoc]
FOAM exiting
Thanks a lot,
Samuele
samiam1000 is offline   Reply With Quote
Old   October 29, 2010, 07:23
Default volume mesh inside a region
CFD user
subhkirti is on a distinguished road
Hi samiam,
Did you use the locationInMesh to specify the portion of your geometry you wanted to keep? You can find the details about its usage in the User guide.
Thanks,
subhkirti is offline   Reply With Quote
Old   October 29, 2010, 07:33
Samuele Z
What does this mean? Also, could you link me the SnappyHexMesh user guide, please??
Do you mean the OpenFOAM u'sg??
Thanks a lot,
Samuele
Old   October 29, 2010, 07:34
colinB is on a distinguished road
Hi
two things:
1) as mentioned in the previous post the location in mesh entry is a point in the part of the mesh that will be kept
2) the correct command is
>this/is/your/case/directory>snappyHexMesh
and maybe one of the arguments specified in your failure message.
You don't have to tell sHM that your are using a Dict-file.
The stl you probably have here:
>this/is/your/case/directory/constant/triSurface
and the sHMD file here
>this/is/your/case/directory/system
then everything should be alright
hope that helps
regards
Colin
Edit: yes he is refering to the OF userguide, where sHM is explained
Edit2: Have you heard about the motorbike tutorial? maybe you should try that first and then adapt your case
to that one.
colinB is offline   Reply With Quote
Old   October 29, 2010, 07:36
Samuele Z
Dear Collin,
thanks for your answer.
Well, just 1 more question:
1. where should I add the line with a point that I wanna include in the meshed region?
Thanks.
Samuele
Old   October 29, 2010, 07:40
in your snappyHexMeshDict file line 160
locationInMesh (X Y Z);
this point must be in the area you want to keep (in your pipe what ever)
and must not coincidence with a face!
Old   October 29, 2010, 07:48
Samuele Z
I think I did a mistake then..
My snappyHexMeshDict file is no bigger than 20 lines..
geometry
Where's the problem in my file?
Old   October 29, 2010, 08:05
Oh that is a problem.
I assumed its not bigger than 20 lines but I really hoped that you just quoted parts of your sHMD.
Well then I highly recommend like I did it in one of my previous posts the motorbike-
tutorial and the user guide.
the motorbike tutorial you find here:
openFoam171/tutorials/incompressible/simpleFoam/motorBike
have a look in the system folder there you find an example file for the sHMD
the user guide you find here
good look with it
and if you have further questions just ask
regards
Old   October 29, 2010, 08:13
Samuele Z
I'll work hard on it.
Thanks a lot.
Just one more question before beginning: in the motorbike tutorial (the Dict file!) I can find different "zones" to describe the surface..
But I do not need them.
Can I delete that part, right??
Old   October 29, 2010, 08:17
yes you can delete them
Old   October 29, 2010, 14:39
ziad is on a distinguished road
Samuele, you might want to read up on sHM in the user's manual. There you'll find a nicely commented simple case.
Thanks a lot.
ziad is offline   Reply With Quote
Old   November 10, 2010, 16:09
Samuele Z
Dear All,
it's again from me.
I read the tutorials and I followed your advice. However, there is a point I can not find anywhere.
I have a complicated geometry and I have its internal mesh. The point is that I don't know how to set which is the inlet and which is the outlet. Of course, I can not write the cell numbers, manually. Is there an automatic tool to find the inlet and the outlet section(s)??
Thanks,
Samuele
Old   November 11, 2010, 04:36
Hi
ususally this is done by the blockMesh background mesh.
Otherwise you have to specify different regions in your stl file so you get different patches and then assign in the files listed in the 0 folder different BC eg inlet outlet to these patches.
check for this the different layers of the motorBike tutorial, but in this case to all of the layers the BC describing them as a wall are assigned
regards
Colin
Old   November 11, 2010, 08:53
Samuele Z
Dear Colin,
thanks for answering.
I will try to have a look. I guess that your second solution (layers!) is the best one.
Bu I am not sure to be able to define different regions in the stl files.. But I will try to do my best.
Thanks again,
Samuele
[CAD formats] Creating waterproof STL using snappyHexMesh or salome Tobi OpenFOAM Meshing & Mesh Conversion 58 May 13, 2020 06:01
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing peterhess OpenFOAM Meshing & Mesh Conversion 2 January 3, 2018 02:54
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. jasv OpenFOAM Meshing & Mesh Conversion 4 May 10, 2016 02:55
[snappyHexMesh] snappyhexmesh doesn't creat mesh in parallel issue? klausb OpenFOAM Meshing & Mesh Conversion 1 March 7, 2015 11:55
[snappyHexMesh] stitchMesh and snappyHexMesh gdbaldw OpenFOAM Meshing & Mesh Conversion 0 December 23, 2009 02:09
