[Gmsh] gmshToFoam: checkMesh errors
Old   November 11, 2010, 09:17
Default gmshToFoam: checkMesh errors
Arina
Akuji is on a distinguished road
Send a message via ICQ to Akuji
Hi there
I have done a mesh in gmsh, then I tried to move it on OpenFoam. At 1st, I do gmshTo FOam, then-checkMesh. But at finish I saw "Failed 1 mesh checks." I use a gmsh-2.4.2 and openfoam- 1.7.0.
And here all:
Time = 0
Mesh stats
faces: 775242
internal faces: 735386
cells: 377657
boundary patches: 4
point zones: 0
face zones: 0
cell zones: 1
Overall number of cells of each type:
hexahedra: 0
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 377657
polyhedra: 0
Checking topology...
Boundary definition OK.
***Unused points found in the mesh, number unused by faces: 127 number unused by cells: 127
<<Writing 127 unused points to set unusedPoints
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces ...
Patch Faces Points Surface topology
nok 0 0 ok (empty)
bottom 10084 5175 ok (non-closed singly connected)
cube 29772 15019 ok (non-closed singly connected)
defaultFaces 0 0 ok (empty)
Checking geometry...
Overall domain bounding box (-890 -1000 0) (1256 1146 1074)
Mesh (non-empty, non-wedge) directions (1 1 1)
Mesh (non-empty) directions (1 1 1)
Boundary openness (-3.99048e-17 -4.59563e-18 -5.13186e-16) OK.
Max cell openness = 2.07714e-15 OK.
Max aspect ratio = 249.614 OK.
Minumum face area = 68.8107. Maximum face area = 4790.95. Face area magnitudes OK.
Min volume = 50.9853. Max volume = 103579. Total volume = 4.94611e+09. Cell volumes OK.
Mesh non-orthogonality Max: 87.2498 average: 26.9519
*Number of severely non-orthogonal faces: 3143.
Non-orthogonality check OK.
<<Writing 3143 non-orthogonal faces to set nonOrthoFaces
Face pyramids OK.
Max skewness = 1.99996 OK.
End
Where is the mistake?
Akuji is offline   Reply With Quote
Old   November 30, 2010, 08:09
T.D. is on a distinguished road
Originally Posted by Akuji View Post
Hi there
And here all:
Time = 0
Mesh stats
faces: 775242
cells: 377657
boundary patches: 4
point zones: 0
face zones: 0
cell zones: 1
hexahedra: 0
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 377657
polyhedra: 0
Face vertices OK.
nok 0 0 ok (empty)
Face pyramids OK.
End
Try to use "frontal" mesh type in options.
also make sure that you have created all physical surfaces and volumes and lines.
Good Luck
T.D. is offline   Reply With Quote
Old   December 1, 2010, 04:30
Arina
Originally Posted by T.D. View Post
Good Luck
Hi, T.D.
I use frontal mesh type un options (it's default)/
About physical surfaces and lines: all lines are included in surfaces. Should I at 1st make a physical lines ans then physical surfaces? Or will be enought to create a surfaces immediatly?
Old   December 1, 2010, 08:21
Hi, T.D.
Every patch you need to use in calculations you must define as physical.
so if your patches are all surfaces that surrounds a volume, in other ways 3D geometry, then you must only define physical surfaces and the physical internal volume.
If it is 2D, then you must define the physical lines and the physical internal surface.
you can send me the gmsh file, i can check it for you.
GoodLuck
Old   November 24, 2014, 09:13
ok
Maimouna is on a distinguished road
Dear T.D.,
I got the same error when I checked mesh in Gmsh '' Failed 1 mesh checks'', my mesh file is showing below
D = 0.0016;
R = 0.0008;
xmin = -0.384;
xmax = 0.384;
ymin = 0;
ymax = 0.320;
zmin = -1;
zmax = 1;
lc = 0.1;
// Number of nodes in x, y and z directions
nx = 100;
ny = 100;
nz = 1;
Point(1) = {xmin, ymin, zmin, lc};
Point(2) = {xmax, ymin, zmin, lc};
Point(3) = {xmax, ymax, zmin, lc};
Point(4) = {xmin, ymax, zmin, lc};
Point(5) = {-0.224, 0.160, zmin, lc};
Point(6) = {-0.224+R, 0.160-R, -1, lc};
Point(7) = {-0.224+R, 0.160+R, -1, lc};
Point(8) = {-0.224-R, 0.160+R, -1, lc};
Point(9) = {-0.224-R, 0.160-R, -1, lc};
Point(10) = {-0.224-R, 0, -1, lc};
Point(11) = {-0.224+R, 0, -1, lc};
Point(12) = {0.384, 0.160-R, -1, lc};
Point(13) = {0.384, 0.160+R, -1, lc};
Point(14) = {-0.224+R, 0.320, -1, lc};
Point(15) = {-0.224-R, 0.320, -1, lc};
Point(16) = {-0.384, 0.160+R, -1, lc};
Point(17) = {-0.384, 0.160-R, -1, lc};
Circle(1) = {6, 5, 7};
Circle(2) = {7, 5, 8};
Circle(3) = {8, 5, 9};
Circle(4) = {9, 5, 6};
Line(5) = {1, 10};
Line(6) = {10, 11};
Line(7) = {11, 2};
Line(8) = {2, 12};
Line(9) = {12, 13};
Line(10) = {13, 3};
Line(11) = {3, 14};
Line(12) = {14, 15};
Line(13) = {15, 4};
Line(14) = {4, 16};
Line(15) = {16, 17};
Line(16) = {17, 1};
Line(17) = {9, 17};
Line(18) = {9, 10};
Line(19) = {6, 11};
Line(20) = {6, 12};
Line(21) = {7, 13};
Line(22) = {7, 14};
Line(23) = {8, 15};
Line(24) = {8, 16};
// Definition of line loop and surface
Line Loop(1) = {5,-18,17,16};
Plane Surface(1) = {1};
Line Loop(2) = {6,-19,-4,18};
Plane Surface(2) = {2};
Line Loop(3) = {7,8,-20,19};
Plane Surface(3) = {3};
Line Loop(4) = {20,9,-21,-1};
Plane Surface(4) = {4};
Line Loop(5) = {21,10,11,-22};
Plane Surface(5) = {5};
Line Loop(6) = {22,12,-23,-2};
Plane Surface(6) = {6};
Line Loop(7) = {-24,23,13,14};
Plane Surface(7) = {7};
Line Loop(8) = {-17,-3,24,15};
Plane Surface(8) = {8};
// Definition of number of nodes on lines
Transfinite Line{5, 17, 24, 13} = 100;
Transfinite Line{18, 16, 19, 8} = 100;
Transfinite Line{10, 22, 23, 14} = 10;
Transfinite Line{4, 6, 2, 12} = 100;
Transfinite Line{15, 3, 1, 9} = 100;
Transfinite Line{7, 20, 21, 11} = 100;
// Definition of the corners of the mesh and creation of a structured
//hexahedral mesh
Transfinite Surface{1} = {1,10,9,17};
Recombine Surface{1};
Transfinite Surface{2} = {10,11,6,9};
Recombine Surface{2};
Transfinite Surface{3} = {11,2,12,6};
Recombine Surface{3};
Transfinite Surface{4} = {6,12,13,7};
Recombine Surface{4};
Transfinite Surface{5} = {7,13,3,14};
Recombine Surface{5};
Transfinite Surface{6} = {7,14,15,8};
Recombine Surface{6};
Transfinite Surface{7} = {16,8,15,4};
Recombine Surface{7};
Transfinite Surface{8} = {17,9,8,16};
Recombine Surface{8};
// Extrusion in the third dimension
Extrude{0,0,zmax-zmin}{
Surface{1,2,3,4,5,6,7,8};
Layers{nz};Recombine;
// Definition of surfaces for boundary conditions
Physical Surface("inlet") = {177,199,45};
Physical Surface("outlet") = {125,103,81};
Physical Surface("top") = {173,147,129};
Physical Surface("bottom") = {33,55,77};
Physical Surface("cylinder") = {155,111,63,191};
Physical Surface("frontAndBack") = {5,4,3,90,134,112,107,85,6,156,133,151,2,8,1,178,3 7,59,68,46,200,165,41};
// Definition of a volume
Physical Volume("volume") = {1,2,3,4,5,6,7,8};
Mesh 3;
Save "channel-with-cylinder.msh";
Could you please tell me where is the problem that shows the error ''Failed 1 mesh checks''?
Lots of thanks in advanced.
Maimouna
Maimouna is offline   Reply With Quote
Old   November 24, 2014, 10:24
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Well, I'm not T.D.
If you get the error, post this error. Otherwise person, who would like to help you, have to create geo-file by copying what you've posted, then run gmsh to create msh-file, run gmshToFoam in an arbitrary case, run checkMesh to learn what exact error you've got.
In fact there are two errors:
 ***High aspect ratio cells found, Max aspect ratio: 155090, number of cells 50787
  <<Writing 50787 cells with high aspect ratio to set highAspectRatioCells
and
    Mesh non-orthogonality Max: 86.6188 average: 20.8455
   *Number of severely non-orthogonal (> 70 degrees) faces: 2260.
  <<Writing 2260 non-orthogonal faces to set nonOrthoFaces
Now take a look at a picture of a mesh (attached to the message). First problem can be solved by reducing size of the cube in y-direction (as any way you going to run 2D case). Non-orthogonality around the cylinder can be solved by rearranging nodes of the mesh. As overall mesh is awful, I've decided not to look exact location of the problem.
alexeym is offline   Reply With Quote
Old   November 24, 2014, 12:16
ok
Dear Alexey,
many thanks for your last post. Actually the error that I got after checkMesh is shown below
maimouna@maimouna-desktop:~/OpenFOAM/OpenFOAM-2.2.2/tutorials/incompressible/pimpleDyMFoam/freeOscillatingCylinderComparisionTest$ checkMesh
| \\ / O peration | Version: 2.2.2 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.2.2-9739c53ec43f
Exec : checkMesh
Date : Nov 24 2014
Time : 17:08:14
Host : "maimouna-desktop"
PID : 5621
Case : /home/maimouna/OpenFOAM/OpenFOAM-2.2.2/tutorials/incompressible/pimpleDyMFoam/freeOscillatingCylinderComparisionTest
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
internal points: 0
faces: 207414
internal faces: 102654
cells: 51678
faces per cell: 6
boundary patches: 7
point zones: 0
face zones: 1
cell zones: 1
hexahedra: 51678
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 0
polyhedra: 0
***Total number of faces on empty patches is not divisible by the number of cells in the mesh. Hence this mesh is not 1D or 2D.
Cell to face addressing OK.
Point usage OK.
Face vertices OK.
Checking patch topology for multiply connected surfaces...
frontAndBack 102465 103869 ok (non-closed singly connected)
bottom 297 596 ok (non-closed singly connected)
inlet 207 416 ok (non-closed singly connected)
cylinder 396 792 ok (non-closed singly connected)
outlet 207 416 ok (non-closed singly connected)
top 297 596 ok (non-closed singly connected)
defaultFaces 891 1000 ok (non-closed singly connected)
Overall domain bounding box (-0.384 0 -1) (0.384 0.32 1)
Mesh (non-empty, non-wedge) directions (1 1 0)
Mesh (non-empty) directions (1 1 0)
All edges aligned with or perpendicular to non-empty directions.
Boundary openness (7.31352789305e-16 8.45626662634e-16 -1.59518906061e-17) OK.
***High aspect ratio cells found, Max aspect ratio: 1344.20375221, number of cells 211
<<Writing 211 cells with high aspect ratio to set highAspectRatioCells
Minimum face area = 2.05992588458e-08. Maximum face area = 0.0353777777778. Face area magnitudes OK.
Min volume = 4.11985176916e-08. Max volume = 0.000216983703704. Total volume = 0.49151195786. Cell volumes OK.
Mesh non-orthogonality Max: 44.1792278785 average: 11.5762701315
Face pyramids OK.
Max skewness = 2.46069682679 OK.
Coupled point location match (average 0) OK.
End
Honestly, I didn't understand where that two errors that you posted in #6 where are come from. Could you please explain me more and what about the error that I got?
Many thanks for your help.
Maimouna
Old   November 24, 2014, 13:22
Alexey Matveichev
I've just copy-pasted your geo-file (that you've posted as quote instead of attaching it).
In your output I was able to find only error with aspect ratio of cell. Aspect ratio threshold is 1000 (http://foam.sourceforge.net/docs/cpp...50565b3157bb4c), in your mesh maximum is 1344. In this case the error can be ignored.
Old   November 25, 2014, 06:10
ok
Dear Alexey,
many thanks for your help.
Best regards
Maimouna
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 13:21
pimpleDyMFoam computation randomly stops babapeti OpenFOAM Running, Solving & CFD 5 January 24, 2018 05:28
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
