[mesh manipulation] makeAxialMesh for multipleRegions
Old   January 4, 2011, 11:00
Default makeAxialMesh for multipleRegions
Matthias Voß
mvoss is on a distinguished road
hi,
is it possible to use the makeAxialMesh for multiple regions by specifying more than one patch to create the "wedges" from?
The tool is running successfully on my multiRegionMesh but since i´m only giving one patch for the wedges to be created from i end up in both regions becoming "wedge-like" but only 2 of the 4 wedges being created.
Any suggestions???
Thanks in advance,
neewbie
mvoss is offline   Reply With Quote
Old   January 5, 2011, 08:00
Assistant Moderator
Bernhard Gschaider
Originally Posted by neewbie View Post
hi,
The util can only handle one patch at a time. Without reprogramming it your best shot will be to use the createPatch-utility to collect the patches from the two regions into one patch and then apply MAM on that. For "documentation" have a look at the example-dictionary that comes with the source code of that utility
Bernhard
Old   January 5, 2011, 08:06
Lightbulb
Matthias Voß
hi,
thanks a lot!! sadly but true.. anyways... it´s a great tool.
I´ll just have to find a way to cut the created super-patches back to their original shapes...
ideas are welcome; i´ll report back here when i found a solution.
btw: when i use the tool for my multiregion mesh i got ALL the faces (in XY) moved from plane to wedge-like shape... but only the one specified through the -wedge option will be named correctly AND none of the original plane patches is really deleted, so i end up with my original + the wedgy ones.
neewbie
[mesh manipulation] makeAxialMesh and axisymmetric flow yassepid OpenFOAM Meshing & Mesh Conversion 5 January 28, 2024 22:38
[Other] Installing makeAxialMesh - strange wmake error krzychu111 OpenFOAM Community Contributions 1 December 19, 2018 18:29
[mesh manipulation] How to make a pipe using makeAxialMesh tomloh OpenFOAM Meshing & Mesh Conversion 15 September 3, 2013 05:52
[Other] Error of using MakeAxialMesh ultility liguifan OpenFOAM Meshing & Mesh Conversion 3 April 16, 2013 05:39
[mesh manipulation] makeAxialMesh - installation issues simulator4711 OpenFOAM Meshing & Mesh Conversion 3 March 21, 2012 07:59
