[blockMesh] Meshing a bent coronary (like pipe) with stenosis (narrowing)
Old   May 10, 2011, 07:09
Default Meshing a bent coronary (like pipe) with stenosis (narrowing)
Martin
RugbyGandalf is on a distinguished road
Hi there
i am trying to simulate the flow in a coronary with narrowing (75% area stenosis)...
Therefor i would like to create a mesh with blockMesh. I already have some results, but they are not satisfying
The problem is, to get the curved and narrowed part generated without any inconstancies.
I defined the points, for the middle of the bent part (45 degrees) and created arc - edges from the ending of the unbent cylinders to the middle plane, with calculated points for the arcs. The arc - points are points of a circle, lying in an angle of 22.5 degrees to the ending cylinder and the middle circle. As you could see on the pictures, one will get inconstancies with this method
I hope this was not to complicating - maybe the pictures will show what i mean!!!
Now the most important question: does anyone have an idea, how to solve this problem?
Regards,
Martin
RugbyGandalf is offline   Reply With Quote
Old   May 10, 2011, 07:23
Martin
MartinB will become famous soon enough
Hi Martin,
you can try to use splines instead of arcs. The bend will be modeled with 5 hex blocks instead of 10.
Or have a try with discretizer...
Martin
MartinB is offline   Reply With Quote
Old   May 10, 2011, 07:33
Martin
dear Martin (nice Name
if i already tried to mesh it with only 5 blocks - the result is to be seen below...
I think i will need the middle circle, for getting the guaranty, that it is a circle cross section at each point of the line...
Old   May 10, 2011, 11:21
Martin
I adapted the arc - interpolation coordinates a little bit - below you will see the result!!!
One problem is left: the inconstancies at the end of the curved part...
Does anyone have an idea how to solve this?
I will try a little bit with splineLines as edges - maybe results will get better..!?
[ICEM] Hexa meshing branched pipe with different angles about its perimeter fascinatedbyCFD ANSYS Meshing & Geometry 1 November 19, 2015 10:11
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 10:49
+ shape circular pipe - meshing possible? Selina Tracy Main CFD Forum 2 January 16, 2003 13:31
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
