[Commercial meshers] problems with .msh mesh
Old   August 31, 2011, 14:01
Default problems with .msh mesh
Paulo Victor Soares e Silva
paulovss is on a distinguished road
I'm having trouble converting a mesh. msh . In the terminal window of my case, when I type the command gmshToFoam, it appears:
-> FOAM FATAL IO ERROR:
wrong token type - expected word found on line 0 the punctuation token '('
file: IStringStream.sourceFile at line 0.
From function operator>> (istream &, & word)
in file primitives / strings / word / wordIO.C at line 76.
FOAM exiting
what it means and how can I solve this problem? I am new to OpenFoam. Thank you.
paulovss is offline   Reply With Quote
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
[ANSYS Meshing] First layter thickness on mesh causing problems Rik102 ANSYS Meshing & Geometry 0 November 4, 2016 09:51
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[Commercial meshers] Problems with ANSYS mesh conversion tdog OpenFOAM Meshing & Mesh Conversion 1 March 31, 2016 17:36
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
