[Commercial meshers] 2D axisymmetric simulation starting with a 2D fluent msh file.... How ? |
November 17, 2011, 00:29 |
Vishal Achasrya
I have been doing 3D simulations of a axisymmetric geometry with a swirling inflow. I had done these earlier outside OpenFOAM, and am now looking to port all of my simulations to OF. I use OF16xt and OF20x , with the extend version mainly. I have done the 3D simulation also in OF and now have that solution ready and i can considerably reduce my computation time by making it a 2D axisymmetric configuration with a swirling inflow component also included in the BC. I have a 2D meshed fluent *.msh file of the 2D cut section of the axisymmetric geometry. I know i can use the fuentMeshToFoam to convert the mesh to foam format, but how do i tell OF that it is an axisymmetric simulation? As in, how do i convert a 2D mesh directly into the wedge mesh for use with OpenFOAM? How do i ensure that the swirling flow component of the momentum equation is also solved for? Any help on which utilities, boundary condition types, etc that should be used would help. Thanks V Last edited by vishalsacharya; November 17, 2011 at 00:30. Reason: more information |
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc | ofslcm | OpenFOAM Community Contributions | 25 | March 6, 2017 10:03 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 09:07 |
[swak4Foam] funkySetFields compilation error | tayo | OpenFOAM Community Contributions | 39 | December 3, 2012 05:18 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
