[Salome] Problem with tetrahedral-mesh (salome) |
March 13, 2012, 12:02 |
Rep Power: 14 |
Hello everybody,
I'm new to OpenFOAM and I want to use CAD-Data meshed with Salome in OpenFOAM. For learning how to use OpenFOAM with structural mechanics I used a simple model. It is a simple beam, which is fixed at the bottom and displaced (0.04m in y-direction) at the upper part. I tried the import (ideasUnvToFoam) of a hexahedral and a tetrahedral mesh with the complete same case. The hex-mesh worked fine and with the tet-mesh I get really strange results which I can't explain (see pics). checkMesh does not complain after the import of the tet-mesh. Unfortunaley the mesh-size is to big, so i could not upload it. I would be very thankful if someone could help me! Best regards Matthias |
March 14, 2012, 05:38 |
Rep Power: 14 |
Hello all,
is there anybody out there, who had a comparable problem or has anybody an idea where I can start searching. I already checked my mesh with checkMesh and the solver converged as well. Another question I have is: one of my boundary conditions is a displacement of 0.04m: oben { type fixedValue value uniform (0 0.04 0) } Now I want that the motion in x- and z-direction is not "0" but changes, so that the boundary "oben" isn't anymore parallel to its initial position. Is there an easy way to do this?. With best regards Matthias |
March 15, 2012, 17:20 |
Lachlan Graham
Rep Power: 16 |
I've had a similar issue in fluid dynamics in laminar pipe flow of non-Newtonian fluids. With hex meshes developed using blockMesh I get converged solutions which agree very well for the pressure drop with the analytical values. With tet meshes with viscous layers developed in Salome, the pressure drop is about 5% too high even though the solutions are well converged. I'm working through some possible issues with mesh quality and choice of discretisation schemes etc. Perhaps these will help. I want to move to more complex gemetries so I need to validate the meshing. Not sure if I have helped, but perhaps there is an issue. Regards, Lachlan |
March 19, 2012, 04:23 |
Rep Power: 14 |
Hello Lachlan,
thank you for your reply! Until now I haven't found a solution for my problem. But I'm still working on it. As alternativity I'm testing snappyHexMesh, because I want to move to more complex geometries, too. Best regards Matthias |
March 20, 2012, 09:59 |
Kyle Mooney
Rep Power: 17 |
Eric Patterson gives some good recommendations for discretization choices for unstructured grids in this Thread (post #5).
http://www.cfd-online.com/Forums/ope...red-grids.html It might improve your solution. |
March 20, 2012, 14:52 |
Rep Power: 14 |
Hi kmooney,
thank you for the link. It sounds interesting and I will try it! Best regards Matthias |
mesh salome cad opefoam |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
[Other] engineFoam new mesh problem | ayhan515 | OpenFOAM Meshing & Mesh Conversion | 5 | August 10, 2015 08:45 |
[ICEM] Problem making structural mesh on a surface | froztbear | ANSYS Meshing & Geometry | 1 | November 10, 2011 08:52 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
salome, openfoam and moving mesh | prhlava | OpenFOAM Running, Solving & CFD | 8 | November 9, 2009 08:59 |
