[mesh manipulation] OpenFoam 2.1.0/x: creation of sets and cellZones.
Like Tree44Likes
Old   June 17, 2012, 20:49
mahdi abdollahzadeh
mm.abdollahzadeh is on a distinguished road
Originally Posted by samiam1000 View Post
Dear mm.abdollahzadeh,
does this allow you to have 2 fluid regions that have a coincident interface?
Dear Samuele
I am also a beginner in Openfoam. but i think it is possible. you can have more than one solid or fluid zones. But in diffrent situation you may need to modify the boundary condition
mm.abdollahzadeh is offline   Reply With Quote
Old   June 17, 2012, 20:51
mahdi abdollahzadeh
Originally Posted by Budlo View Post
Hi All
1-Why we use uniform value(300) in conjugate B.C ? (the conjugate boundary must to be solve)
What is diferent between: Compressible::turbulentTemperatureCoupledBaffleMix ed,
Compressible::turbulentTemperatureCoupledBaffle,
2- In chtMultiRegionFoam in OpenFoam 2011:
What is Ychar and Ypmma files in boundary condition ?
Dear namdar
I just know that the temperature that you are giving is an initial guess for the temperature of the wall to allow calculation of heat flux on diffrent side of interface.
Old   June 17, 2012, 21:23
Elh. A2. BAH
ebah6 is on a distinguished road
Thanks Jie for updating the thread.
my best regards.
ebah6 is offline   Reply With Quote
Old   June 18, 2012, 03:22
Samuele Z
samiam1000 is on a distinguished road
Originally Posted by mm.abdollahzadeh View Post
Dear Samuele
Dear Mahadi,
any idea about how to do this? Just an hint to begin..
Thanks,
Samuele
samiam1000 is offline   Reply With Quote
Old   June 18, 2012, 05:37
lore
lovecraft22 is on a distinguished road
Send a message via Skype™ to lovecraft22
Thank you Jie, that's great. But, how do you find the numbers to enter within the boundary file?
lovecraft22 is offline   Reply With Quote
Old   June 18, 2012, 07:16
Elh. A2. BAH
Hi Lore,
The boundary file should be created automatically when you export to openFoam. The same thing with the other four files (faces, points, etc.)
Myself, I use pointwise. The only things I add to the boundary file after exporting from PointWise to OpenFoam are:
* to make sure I get cyclicAMI instead of just cyclic.
* the matchTolerance, the neighbourPatch, and the transform items.
Regarding the matchTolerance I think (but not sure) that it is at 1e-4 by default.
The neighbourPatch is the other of the pair rotor/stator. The example by Jie is explicit in this regard.
I hope this helps.
Old   June 18, 2012, 07:21
lore
Thank you ebah, so you don't need to set nFaces and startFace.
Also, what are the advantages of using pointwise (or any other software) compared to snappy? Can all of this be done using snappy only?
Old   June 18, 2012, 07:32
Elh. A2. BAH
I guess you can use snappy.
One thing is that if you are already familiar with a software pointwise or anyone else that can export to openFoam format, it save you some time.
Personally, I run into a bit of trouble with snappy, I couldn't solve it. So I switch to what I was a bit more familiar with.
Sorry, to answer to your question, even when you are using the OpenFoam embedded mesh generator with the blockMeshDict, all you deal with is this file; the boundary file and others are generated when you run the blockMesh command.
Old   June 28, 2012, 00:31
Jie
jiejie is on a distinguished road
Hi Guys
Would you be able to share the set up for fvScehem and fvSolution when using AMI interface? I tried to re-use the propeller mesh from the GGI (openfoam-1.6-ext) with AMI (openfoam-2.1.1), but I found the simulation is very unstable with AMI (pressure solver is doing more than 400 iterations for every timestep), which is stable with GGI. I used the same fvScheme and fvSolution from the propeller tutorial for my case with AMI. I remember I did change some of the schemes with the GGI, but some of those schemes are not available in openfoam-2.1.1.
It will be really great if anyone can share some advice about this.
Thanks
Jie
jiejie is offline   Reply With Quote
Old   June 28, 2012, 00:43
mahdi abdollahzadeh
Dear Jie
Could you please tell me which solver of Openfoam you are using for turbomachinary?
I am new in Openfoam, and I want to model a rotor blade (NACA67).
Best
Mahdi
Old   June 28, 2012, 00:46
Jie
Hi Mahbi
I am just using the standard pimpleDyMFoam.
Jie
mm.abdollahzadeh likes this.
Old   July 23, 2012, 08:35
mahdi abdollahzadeh
Dear Samuel
if you have just two fluid zone with a interface between them. you can do this.
1-create the Mesh of each zone separately
2-Setup a running folder according to Chtmultiregion tutorial
( i mean create folders with the name of your zones and etc ... )
3-for creating coupled interfaces forexample for conjucate heat tarnafer , you should edit the type of your boundary condition in the boundary file in polymesh for each zone.
you need to replace it with :
type directMappedWall;
nFaces 350;
startFace 119925;
sampleMode nearestPatchFace;
sampleRegion Zone2; // name of the neighbor zone
samplePatch interfaceD; // name of the coincident boundary
offsetMode uniform;
offset (0 0 0);
4- then you need just to apply the correct boundary conditions in your Zero Folder.
for a scaler which is solving in both region and the interface boundary is coupled between the two zone you can use , turbulentTemperatureCoupledBaffleMixed.
Best
Mahdi
marv91 likes this.
Old   August 1, 2012, 11:59
turbulencious is on a distinguished road
hello Madi,
I found your last post here very relevant to the problem that I encounter. Can you elaborate more? I have followed the steps that you give here (change the boundary files in polyMesh from mappedWall to directMappedWall) but I find difficulties to chose a BC to couple the temperature between solid and fluid. My flow is laminar and I want to couple the temperature. When I use zeroGradient the temperature of the solid does not change at all
solver:chtMultiRegionFoam
version: OF-2.1.1
thank you very much in advance
cordially,
giorgos
turbulencious is offline   Reply With Quote
Old   August 2, 2012, 10:40
mahdi abdollahzadeh
Originally Posted by turbulencious View Post
hello Madi,
version: OF-2.1.1
cordially,
giorgos
Dear giorgos
So you can change the type of boudary to directmappedwall.
the next step is to use the follwing boundary conditions in 0 folder for temperature :
Example usage:
myInterfacePatchName
type compressible::turbulentTemperatureCoupledBaffle;
neighbourFieldName T;
K lookup;
KName K; // or none
value uniform 300;
or
type compressible::turbulentTemperatureCoupledBaffleMix ed;
K lookup;
KName K;
value uniform 300;
Best
Mahdi
Old   August 8, 2012, 04:05
thank you very much!
Old   August 13, 2012, 12:12
maHein is on a distinguished road
When I try directMappedWall, I get an error message:
--> FOAM FATAL ERROR:
    patch type 'genericPatch' not type 'mappedPatchBase'
    for patch contact_fluid of field T in file "/disk401/home/heinri8/Simulation/FlatPlate/flatPlate_LTS/0/fluid/T"
    From function turbulentTemperatureCoupledBaffleMixedFvPatchScalarField::turbulentTemperatureCoupledBaffleMixedFvPatchScalarField
    const fvPatch& p,
    const DimensionedField<scalar, volMesh>& iF,
    const dictionary& dict
    in file derivedFvPatchFields/turbulentTemperatureCoupledBaffleMixed/turbulentTemperatureCoupledBaffleMixedFvPatchScalarField.C at line 99.
FOAM exiting
Looks like directMappedWall has been renamed to mappedWall in 2.1.0, (see official 2.1.0 release announcement)
maHein is offline   Reply With Quote
Old   October 18, 2012, 17:47
sivakumar selvaraju
sivakumar is on a distinguished road
Send a message via Skype™ to sivakumar
Hi Guys,
I have problem to create Sets and cellZones, I tried to follow Jiejie steps (he explained the steps in the previous post) .
while executing setSet, I am getting the following error,
Create time
Create polyMesh for time = 0
Time:0 cells:460000 faces:1402700 points:483021 patches:12 bb-1.06977 -0.559055 0.177709) (3.08761 0.0363306 0.771367)
cellSets:
fan size:0
cellZones:
fluid size:460000
faceZones:
default-interior size:1357300
Time = 0
mesh not changed.
Please type 'help', 'quit' or a set command after prompt.
readline>
I dont know why the cellSets: fan size 0
can you guys help me to sort out this problem.
Thanks for your time and answers,
Sivakumar
sivakumar is offline   Reply With Quote
Old   November 12, 2012, 15:45
hfs
hfs is on a distinguished road
Hello!
I have an STL and want to get faceZones according to it
how can I use setSet to do that?
Thank you!
hfs is offline   Reply With Quote
Old   June 18, 2013, 07:21
reza sadeghi
reza1111 is on a distinguished road
Hi everybody
I am new in OF and I am going to use AMI capability. my rotary interface isn't cylindrical.
my case is a rotary spheroidal zone in a cubic domain . can I do my case using OF?
Please give me some hints about AMI ability.
Thanks in advance,
Reza
reza1111 is offline   Reply With Quote
Old   July 16, 2013, 04:55
reza1980's Avatar
reza
reza1980 is on a distinguished road
Hi All,
I hope you are fine. I am working on AMI to handle a propeller case through OF2.1x. My results seems not acceptable.
would you please let me your instruction to implement AMI.
I use this:
* Export two parts like Stator and Rotor from pointwise to OpenFoam
* Merge to parts as mergeMeshes Stator Rotor
* Update Boundary (Add cyclicAMi and tolerance)
* Use splitMeshRegions -makeCellZones -overwrite to make cellZones
Reza
kiddmax likes this.
reza1980 is offline   Reply With Quote
Getting Started with OpenFOAM wyldckat OpenFOAM 25 August 14, 2022 13:55
