Home > Forums > Software User Forums > OpenFOAM > OpenFOAM News & Announcements > OpenFOAM Announcements from Other Sources
multiSolver released
Like Tree3Likes
  • 1 Post By marupio
  • 1 Post By marupio
  • 1 Post By marupio
Old   July 23, 2010, 08:30
Default multiSolver released
David Gaden
marupio is on a distinguished road
Hi Foamers,
I am pleased to announce the release of multiSolver, an extension to OpenFOAM that allows you to run numerous solvers in sequence on a single dataset.
Why would you need that?
  • Arbitrarily changing boundary conditions mid-run;
  • Modelling multi-step processes in a single application (e.g. injection & settling);
  • Modelling a problem characterized by 2 different timesteps (e.g. stirring & biochemical reactions).
See this page on the wiki for further details:
http://openfoamwiki.net/index.php/Contrib_multiSolver
Share and enjoy!
alexey2petrov likes this.
marupio is offline   Reply With Quote
Old   March 28, 2011, 16:04
Default Parallelization?
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
Are parallel runs supported yet? I'm using OF-1.6-ext and this would be fantastic for my applications.
Dan
chegdan is offline   Reply With Quote
Old   March 28, 2011, 17:20
David Gaden
Hi Dan,
No, it isn't. I haven't worked with parallel very much, so I'm not familiar with the directory structure and how the processors communicate. I don't forsee it being challenging, but I don't have the time right now. I would be open to collaborating on its development, though!
I expect to be putting mesh motion in this summer. I'll also have an updated version with minor changes before the 6th workshop.
-Dave
Old   March 28, 2011, 17:36
Daniel P. Combest
Originally Posted by marupio View Post
Hi Dan,
-Dave
I would be willing to collaborate on this one to get it working. I will take a look at the code and see if I can offer any help. It looks like a fantastic tool and could definitely be worth getting it to work in parallel. I'll get into it starting tomorrow.
Dan
Old   March 28, 2011, 21:08
David Gaden
Grand! I've sent you a PM with some more information. I hope we can get this working!
Old   April 6, 2011, 10:19
David Gaden
multiSolver now fully supports parallel simulations.
Old   May 20, 2011, 06:19
Peter Canfield
canfield is on a distinguished road
Hello. First of all, great work with this solver!
I do seem to have hit an obstacle though. You say it supports parallel processing. I don't seem to be able to figure out how to get the solver to run. I have decomposed the case as explained on the WIKI page, but when I try to run the case using mpirun .... it won't run. It seems that there are no "0" directories in the processor directories. I guess I am just missing something trivial, but I haven't worked it our yet. Maybe you can give me a tip?
canfield is offline   Reply With Quote
Old   May 20, 2011, 09:17
David Gaden
It sounds like you aren't using a multiSolver-enabled solver. What solver are you using? The only publicly available one is multiSolverDemo, which came with the installation. The wiki page also shows how to easily create a multiSolver-enabled application.
If you are using the correct solver... then what errors are you getting?
Old   May 20, 2011, 09:26
Peter Canfield
OK, here goes. I compiled my own multisolver called multiBubbleSolver. Incidentally, it works fine on a single processor. Then I decompose as per instructions on the wiki. then I input:
mpirun -np 4 multiBubbleSolver -parallel
and I receive this:
[1] --> FOAM FATAL ERROR:
[1] Initial time directory missing for solver domain [interFoam1]. Expecting "/home/peter/OpenFOAM/peter-1.7.x/run/BUBBLES/processor1/multiSolver/interFoam1/initial/0"
[1]
[1] From function multiSolver::checkTimeDirectories
[1] in file multiSolver/multiSolver.C at line 320.
...The rest of the errors seem to be caused by the missing directory.
The same thing happens if I try using multiSolverDemo in parallel.The directory structure in the proc* folders is as follows ("0" directory missing):
processor*
-constant
-system
Old   May 20, 2011, 09:46
David Gaden
Hi Peter, I've managed to duplicate the issue on my machine. I'll try to resolve it as quickly as I can, but I have to leave for work soon. I'll let you know...
-Dave
Old   May 20, 2011, 10:29
David Gaden
Hi Peter, I've got a work-around you can try for now... the bug fix should come within a few days. Edit the controlDict file (not the multiControlDict), and set:
startFrom: startTime;
startTime: -1;
Then try the long decompose command in the wiki. I have to head off to work now. Hope it works!
canfield likes this.
Old   May 20, 2011, 10:38
Peter Canfield
Nice job! works fine for the demo; I'll have a go at my case later on. Thanks.
Old   June 3, 2011, 09:44
David Gaden
The bug fix has been completed. Parallel decomposing should nolonger omit the initial directories!
Attesz likes this.
IcofsiFoam not supported under released 141 package pi06jl6 OpenFOAM Running, Solving & CFD 4 June 26, 2008 13:59
coal combustion:heat released Maria Luiza CFX 0 July 5, 2006 13:03
OpenFOAM Version 1.3 Released OpenFOAM discussion board administrator OpenFOAM Announcements from ESI-OpenCFD 0 March 29, 2006 18:06
OpenFOAM Version 1.0.2 Released Admin (Admin) OpenFOAM Announcements from ESI-OpenCFD 0 January 12, 2005 06:33
partciles released in different instants Jason FLUENT 2 September 15, 2004 05:16
