Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Best approach for station pressure on boat hull
Old   July 18, 2011, 12:11
Default Best approach for station pressure on boat hull
CThib is on a distinguished road
Hi Everyone,
I am new to Paraview and unsure of which approach I should use to calculate the total pressure at a station* and display the results. Right now I'm reading the VTP files and doing the calculations in Fortran, which works with VTP files, but not with some of the VTK files (plus, I just want to do this in Paraview).
The way I'm doing it in fortran is to look at the mesh, determine which station it belongs to, calculate the normal and area of the mesh element (they are all triangles in this case), and sum up the total force.
Is this easily doable with a custom filter?
Thank you.
* A station is an arbitrary transverse cut with a normal parallel to the X axis, where the X axis is the long dimension of the boat (parallel to the axis of the bow-to-stern).
CThib is offline   Reply With Quote
Old   May 21, 2012, 03:04
hs
parkh32 is on a distinguished road
Hi CThib
Have you solved your problem ?
hs//
parkh32 is offline   Reply With Quote
Residuals and forces spiraling out of control before failing edomalley1 OpenFOAM Running, Solving & CFD 3 September 7, 2018 10:42
Pressure Outlet Guage pressure Mohsin FLUENT 36 April 29, 2016 17:16
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Pressure distribution along hull sam CFX 1 September 13, 2008 17:09
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
