Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Tube filter in Paraview
Like Tree1Likes
  • 1 Post By werweisswas
Old   December 10, 2012, 06:18
Default Tube filter in Paraview
werweisswas is on a distinguished road
Hi all,
I am a beginner in using Paraview. Hopefully someone can be of help here.
I have been trying to do the following.
1.) Generate a line using Polydata in vtk format and assign it color
before hand. The color coding of the line is something i need.
2.) Read the file in paraview and apply the tube filter on it to create
tube like display on the lines.
Here is the problem: The color of the tube is different from the color of
the "source" line used to generate the tube. The tube is displayed in the pipeline browser amd the color of the tube is different from the line in the display. No amount of reediting sofar i tried, helped. However if i save the state and re-read the (tube) file , the coloring of the tube corresponds exactly to the line which was used to generate the tube!!! There must be something with the display/coloring options that i am unable to grasp. Can someone suggest a way in which i can avoid having to re-read the file and apply the same coloring to the tubes as the underlying lines?
Many thanks in advance...
sourav90 likes this.
werweisswas is offline   Reply With Quote
double tube heat exchanger mehyan CFX 4 December 8, 2015 16:44
[Other] How to set up a dynamic mesh for a piston moving through a tube of variable diameter? karkar OpenFOAM Meshing & Mesh Conversion 0 July 4, 2012 06:54
Filter menu of ParaView is disabled after upgrading from Ubuntu 10.04 to 10.10 maysmech OpenFOAM 12 July 19, 2011 16:13
the integrate filter paraView bruxellois OpenFOAM 0 October 3, 2010 18:08
[OpenFOAM] Mass flow rate with Paraview 330 marta_colomer ParaView 2 October 14, 2008 10:27
