Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Export data from paraview
Old   October 25, 2010, 14:55
Default Export data from paraview
Michel
Michel_HB is on a distinguished road
today I was wondering about strange results. I exported /saved the Data from "plot over line" and compared the results to a plot in matlab and got the result in the attached picture. Upper Picture is from Matlab, lower one was made with "plot over line"...
Did anyone made the same experience??
Thanks a lot,
Michel
Michel_HB is offline   Reply With Quote
Old   October 26, 2010, 05:54
Nima Samkhaniani
nimasam is on a distinguished road
whats ur question?
as i see values in matlab pic differ from value in paraview pic
are u sure that u use true set of values for both configuration ?
nimasam is offline   Reply With Quote
Old   October 26, 2010, 06:04
Michel
my question is if anyone made the same experience...
and I am sure that this is the same set of values..
Old   October 26, 2010, 06:34
Gijsbert Wierink
gwierink is on a distinguished road
Could it be that the paraview plot has different interpolation? I.e. that one plot is cell face interpolated and the other cell center values? There is a "Cell Centers" filter in ParaView, maybe interesting to have a look at ...
Regards, Gijs
gwierink is offline   Reply With Quote
Old   May 15, 2013, 03:21
Default Python for save data
Mehdi GHOZALI
Dadou is on a distinguished road
I'm using paraview for extract some data from Probelocation. I have 88 Probelocation and I only know how to save data manually and it's taking me too much time
Does someone know if there a way to make this automatically using mtalab or python or anything else?
Thank you
Mehdi
Dadou is offline   Reply With Quote
Old   May 15, 2013, 03:59
Nima Samkhaniani
you can use sampleDict or sample function in your controlDict, then you would have those points data in file, then with python scrtips you can see it
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
Old   May 16, 2013, 08:21
Mehdi GHOZALI
I've never used it.
I asked around and they told me that I have to put in sampleDict type Cloud and then write the 88 points ?
Do you know what that means and what's the format of the output data ?
Thnak you
Old   May 16, 2013, 12:28
Nima Samkhaniani
dear mahdi you can find the usage of sampleDict from OpenFoam tutorials
here is some cases which you can find sampleDict
./applications/utilities/postProcessing/sampling/sample/sampleDict
./tutorials/stressAnalysis/solidDisplacementFoam/plateHole/system/sampleDict
./tutorials/electromagnetics/mhdFoam/hartmann/system/sampleDict
./tutorials/compressible/sonicFoam/laminar/shockTube/system/sampleDict
./tutorials/compressible/rhoCentralFoam/shockTube/system/sampleDict
./tutorials/compressible/rhoCentralFoam/LadenburgJet60psi/system/sampleDict
./tutorials/compressible/rhoCentralFoam/biconic25-55Run35/system/sampleDict
./tutorials/heatTransfer/buoyantSimpleFoam/buoyantCavity/system/sampleDict
Old   May 17, 2013, 03:53
Mehdi GHOZALI
Thanks for your help
I'll look it up
[General] “Upload” vtk data from client to server in paraview script Jack001 ParaView 0 March 8, 2018 07:27
Export Surface LIC data from Paraview to Tecplot? hxaxtma Tecplot 1 July 2, 2014 04:55
[General] paraview ignores SPACING in STRUCTURED_POINTS vtk data? jaffar ParaView 0 November 27, 2012 09:36
[OpenFOAM] extracting data from paraview tharem ParaView 1 January 17, 2011 23:45
Data export with paraview? zhang OpenFOAM 4 July 25, 2010 07:34
