Home > Forums > Visualization & Post-Processing Software > ParaView
[General] Export to CSV using CreateWriter
Old   September 2, 2013, 02:37
Default Export to CSV using CreateWriter
Julien de Charentenay
julien.decharentenay is on a distinguished road
Send a message via Skype™ to julien.decharentenay
I am trying to write a python script that export a patch values to a CSV file.
Using the GUI, one would do the following:
1) Load the case (openFoam in my case);
2) Select the relevant item in the pipeline browser;
3) Select File > Save Data.
The code that I entered in the python shell is as follows:
w = CreateWriter("minX.csv")
w.UpdatePipeline()
del w
It returns neither error message, nor does it create the csv file (which I am looking for in the ParaView directory). If I change the file to be writen to "minX.vtm", it does write file(s) - but not in a format that is easy to read and use.
I am using ParaView 3.98.1 32b on Windows.
Julien
julien.decharentenay is offline   Reply With Quote
Old   September 2, 2013, 21:09
I have bypassed my problem by using a Programmable Filter that output the data in a vtkTable.
The code stated above then correctly output the data from the vtkTable.
[OpenFOAM.org] blockMesh issue on openfoam6 startup - ubuntu 16.04 bjdarrer OpenFOAM Installation 7 August 25, 2020 19:15
[foam-extend.org] foam-extend-4.0 gcc errors & maybe paraFoam powerline332 OpenFOAM Installation 3 May 24, 2018 21:16
A CFX-POST error (ver 14.5.7) wangyflp88 CFX 2 July 22, 2017 00:17
Unable to install OpenFOAM 1.6-ext Maimouna OpenFOAM Installation 23 May 8, 2014 05:47
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
