[OpenFOAM] paraFoam for aachenBomb particle tracing |
October 1, 2015, 12:39 |
#21 |
James Feng
Rep Power: 12 |
Thanks, Novo. I found it can work simply by checking the "Skip Zero Time" box on paraview.
Since you are into it, I have another question with particle tracing. Now I can easily display particles and watch their motion by marching time steps. But I haven't figured out how to plot individual particle trajectories, which I saw people presenting with Fluent simulations. I wonder if you learned any tricks with paraFoam. Thanks again. |
October 1, 2015, 13:38 |
#22 |
novo
Rep Power: 10 |
Not yet... but I plan to test it too. So please if you succeed any developments. I will keep this in mind too.
And btw. I have not found information about how to set the injection velovity for particles from the calculated velocity data (e.g. performed with icoFoam solver). Do you have any info I could follow on this? |
February 7, 2018, 15:23 |
#23 |
Ali Shayegh
Rep Power: 10 |
Using paraFoam
First you execute paraFoam as usual but you select only in the data to be load the fields and the mesh of the continuous phase. Then you click on the Open button (or File -> Open in the menu). You select the case.OpenFOAM file created by paraFoam. So you can load again the data of the case. But this time, you select
To visualize the particle, use the Glyph filter (cf. end of previous paragraph). |
parafoam, particle tracing |
UDF for particle interception with pt_termination fortran routine | abcdefgh | CFX | 6 | October 6, 2019 13:30 |
Particle tracking error | alchem | OpenFOAM Bugs | 5 | May 6, 2017 16:30 |
particles leave domain | Steffen595 | CFX | 9 | March 7, 2016 16:19 |
injection problem | Mark New | FLUENT | 0 | August 4, 2013 01:30 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 01:29 |
