July 8, 2014, 05:57 |
Compute Surface Flow & Integral
Victorien
Rep Power: 11 |
Hi everybody,
I have two question on the post-processing with ParaFoam : On the one hand, my issue is concerning the Surface Flow filter. I can not use this filter on my pipeline. Maybe I didn't understood how to manipulate it. I work on a cube, and want to know the flow on one surface. So I slice this surface and try to put the Surface Flow filter after, but it don't work. I tried converting my Foam case with foamToVTK and then open the vtk file with Paraview, and do the same as I said befor, without success. On the other hand, I wanted to know if it's possible to compute an integral on an arbitrary domain. I tried the Integrate Variables filter but it compute the value of T at the point (0.5 0.5 0.5) (my cube is [0,1]^3) Does Paraview allow to compute more complex integrals, if we give it a expression ? Thank you for your responses, Victorien |
integral, parafoam, paraview, surface flow |
[General] Mass Flow Using Surface Flow Filter Incorrect | t8fanning | ParaView | 1 | March 13, 2017 05:56 |
[swak4Foam] funkyDoCalc mass flow over stl surface? | lourencosm | OpenFOAM Community Contributions | 0 | November 28, 2014 07:50 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
Surface inejction- steady state - mass flow rate | CFD-student | FLUENT | 0 | January 25, 2012 13:40 |
mass flow rate on the Iso-clip surface & interior | Sunil Gupta | FLUENT | 0 | April 22, 2008 09:29 |
