Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] paraFoam not working
Old   October 16, 2014, 05:24
Default paraFoam not working
ArathoN
ArathoN is on a distinguished road
I Installed paraview 4.1 and this broke the paraFoam, it will not load the mesh or anything related to the case. I unistalled paraview and reinstalled the version built for openfoam 230(from repository) but nothing it still doesn't work.
If I use only the command
paraFoam
it will give me this error:
ERROR: In /home/opencfd/OpenFOAM/ParaView-4.1.0/VTK/Common/ExecutionModel/vtkExecutive.cxx, line 754
vtkPVCompositeDataPipeline (0x2a85a80): Algorithm vtkPV4FoamReader(0x2a7ac10) returned failure for request: vtkInformation (0x2a8c0c0)
  Debug: Off
  Modified Time: 91023
  Reference Count: 1
  Registered Events: (none)
  Request: REQUEST_INFORMATION
  FORWARD_DIRECTION: 0
  ALGORITHM_AFTER_FORWARD: 1
I tried also the command:
paraFoam -builtin
In this case no error shown but also no mesh or fields loaded.
Do you have an idea how to resolve this?
ArathoN is offline   Reply With Quote
Old   October 17, 2014, 03:22
ArathoN
Ok solved.
UDF is working in Laptop, but not working in Serial Cluster Tanjina Fluent UDF and Scheme Programming 0 December 20, 2013 21:42
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 01:41
XiFoam : paraFoam not working researcher OpenFOAM 3 August 26, 2013 20:26
[OpenFOAM] OpenFoam (Ubuntu): paraFoam via Xming+PuTTY raketenmaid ParaView 4 February 5, 2013 05:20
[OpenFOAM] pointVectorField in ParaFoam s_braendli ParaView 0 April 22, 2010 08:36
