Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] 0-velocity countour paraFoam
Old   October 15, 2014, 13:18
Default 0-velocity countour paraFoam
ArathoN
ArathoN is on a distinguished road
I've simulated the backward facing step and i wanted to show the 0-velocity contour in the circulating region but i have no idea how to do it. Any help?
ArathoN is offline   Reply With Quote
Old   October 17, 2014, 03:30
ArathoN
no one has an idea? I searched a method to isolate/trace the cells with zero velocity but found nothing.
Old   October 21, 2014, 15:06
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
First you should use the calculator filter to generate a scalar variable magU, which you can than use to generate a contour (with value 0) with the contour filter.
Regards,
Tom
tomf is offline   Reply With Quote
Old   October 21, 2014, 20:48
ArathoN
Originally Posted by tomf View Post
Regards,
Tom
I can't create a countour for magU = 0 it gave me this error:
Warning: In /home/opencfd/OpenFOAM/ParaView-4.1.0/ParaViewCore/ServerManager/Rendering/vtkSMPVRepresentationProxy.cxx, line 279
vtkSMPVRepresentationProxy (0x75b45f0): Could not determine array range.
do you have an idea how to solve this? If you want i can pass you a case.
Old   October 22, 2014, 03:14
Tom Fahner
I thought about this and came to the conclusion that maybe there is no cell centre where the velocity magnitude is exactly 0? This would not be strange since we are interpolating between values that are strictly nonnegative and discrete. So unless there is a cell with a magnitude of 0 there is probably no contour to be created. Maybe instead of the magnitude you could calculate the velocity in the freestream direction and make a contour of that. This could be negative at some locations (reversed flow) meaning that you could have a value of 0 in your interpolation.
Regards,
Tom
Old   October 22, 2014, 13:27
ArathoN
I've done that with the stream tracer and you'll see the recirculating region, however you can't isolate the "line" with 0-velocity that separates the recirculating region from the outer flow. Still no idea on how to define that streamline.
I've also been thinking of a way to define the center of the circulation region other than seeing the flow pattern and guess its position.
Superimposing 2 Velocity fields For Model inputs in Comsol f.black COMSOL 0 August 2, 2017 09:35
[OpenFOAM] Take derivative of mean velocity in paraFoam hiuluom ParaView 13 April 26, 2016 06:44
Velocity in Porous medium : HELP! HELP! HELP! Kali Sanjay Phoenics 0 November 6, 2006 06:10
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
