Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Obtain Scalar field data in a dat file.
Old   March 25, 2015, 05:30
Default Obtain Scalar field data in a dat file.
Ashish Vinayak
ashish.vinayak is on a distinguished road
I'm trying to find a way to get all the plot data from the plot over line function into a .dat file.
Here's what I've done in detail.
At a location in the pipe, I have used the plot over line function to get a plot of pressure vs pipe length. I've attached a screenshot of the line. I would like to get the values of pressure on this line in a .dat file or any file which can be manipulated. Is there a way to this? I've been looking all over!
Thank you
Screenshot from 2015-03-25 11:27:33.jpg
ashish.vinayak is offline   Reply With Quote
Old   March 25, 2015, 07:52
blacksquirrel is on a distinguished road
Hi Ashish,
There are different ways to obtain your .dat file.
E.g. in paraview: You make your plot over line. Now take a look in the menu File/Save Data (or Ctrl S) that will save you selected data (the line) in a .csv file., which you can open with a text-editor or spreadsheet.
Note, this will probably give you interpolated data.
Another possibility would be the sample utility from OpenFoam: (http://www.openfoam.org/docs/user/sample.php). Here you can define your line as well, and write the desired fields into a dat file. It is a good tool, so you should take a look into this. It allows especially to get the "real" cell values and not interpolated data.
Regards
Squirrel
blacksquirrel is offline   Reply With Quote
cfd, data, openfoam, plot, pressure
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 12:41
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 13:59
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 10:57
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
