May 12, 2015, 17:16 |
VTK error running paraView
Grzegorz Karpiński
Rep Power: 11 |
Hello All,
I'm not sure if "Mesh Utilities" is good section to post my thread: - I'm using OF 1.6-ext and trying to run tutorial "SimpleEngineStem.tar.gz" from: http://cfd-online.com/Forums/openfoa...changes-4.html - I ran: 'sh ./Allrun' and after finish calculations 'paraFoam' - after click on 'apply' in paraView window mesh displayed well. - after click on "play button" (trying to move one or multiple steps) mesh disappeared and following message appeard: p, li { white-space: pre-wrap; } FORWARD_DIRECTION: 0 On shell appeared following error message: "grzegorz@grzegorz-Lenovo-G700:~/Pulpit/simpleEngineStem$ paraFoam created temporary 'simpleEngineStem.foam' Warning: In /build/buildd/paraview-4.0.1/VTK/IO/Geometry/vtkOpenFOAMReader.cxx, line 4725 vtkOpenFOAMReaderPrivate (0x23cdcb0): Numbers of faces in faces 11015 and owner 10955 does not match ERROR: In /build/buildd/paraview-4.0.1/VTK/Common/ExecutionModel/vtkExecutive.cxx, line 754 vtkPVCompositeDataPipeline (0x23c57d0): Algorithm vtkPOpenFOAMReader(0x23ba2d0) returned failure for request: vtkInformation (0x2e3e940) Debug: Off Modified Time: 182665 Reference Count: 1 Registered Events: (none) Request: REQUEST_DATA FROM_OUTPUT_PORT: 0 ALGORITHM_AFTER_FORWARD: 1 FORWARD_DIRECTION: 0" //////////////////////////////////////////////////// Message Numbers of faces in faces 11015 and owner 10955 does not match suggest me that error can be somewhere in mesh (that's why I post here my thread). Do you have any idea where is the problem? I appreciate of any help Best Regards Grzegorz |
May 16, 2015, 02:08 |
Grzegorz Karpiński
Rep Power: 11 |
Obviously it is not mesh problem - I'm real newbie. Solution for other beginners:
foamToVTK cd VTK paraview best regards Grzegorz |
October 16, 2015, 13:30 |
Rep Power: 12 |
October 18, 2015, 03:43 |
#4 | |
Rep Power: 12 |
Maybe this is interesting not only for you. I encountered the same problem that you've had. It strangely appeared when I re-ran an older case of mine with a new foam version. If this error appears, have a look, whether decomposePar created a directory Code:
processor0/constant/polyMesh Code:
processor0/0/polyMesh Code:
if [ ! -d processor0/constant/polyMesh ] then mkdir -p processor0/constant for coreDir in processor* ; do cp -r $coreDir/0/polyMesh $coreDir/constant done fi Regards, Max edit: this only works for some cases. I still have one case where the error occurs and I cannot view the mesh... please, if anyone finds a solution, please tell us. edit2: I posted a solution (work around) here: http://www.cfd-online.com/Forums/ope...fext3-1-a.html Last edited by ma-tri-x; November 4, 2015 at 09:24. |
November 9, 2015, 09:58 |
Grzegorz Karpiński
Rep Power: 11 |
Below you can see solution for my problem:
November 10, 2015, 06:50 |
#6 | |
Rep Power: 12 |
I know that solution you've posted, but it didn't work for my case (you could just view the mesh but not the timesteps). Thanks anyway! Regards, Max |
[OpenFOAM] Paraview problem: loading the VTK cellSets changes the time | anon_q | ParaView | 1 | November 3, 2018 20:53 |
[General] Creating VTK image compatible to Paraview Visualizer | het | ParaView | 0 | January 7, 2016 08:20 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
[General] paraview ignores SPACING in STRUCTURED_POINTS vtk data? | jaffar | ParaView | 0 | November 27, 2012 09:36 |
paraFoam reader for OpenFOAM 1.6 | smart | OpenFOAM Installation | 13 | November 16, 2009 21:41 |
