Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Decomposed case
Old   February 25, 2016, 10:11
Default Decomposed case
yeharav is on a distinguished road
Hi all,
I am trying to load OF decomposed case using the python simple of pv4.4.
So far I used the script
X = OpenFOAMReader(FileName='X.foam')
X.MeshRegions = ['internalMesh']
X.CellArrays = ['U']
X.CaseType = 'Decomposed Case'
print(X.TimestepValues)
in OpenFOAM python console.
I see that I have to press the 'apply' button for things to load (and get the decomposed case).
What is the scripting equivalent. I have tried X.ReadPipeline() and X.ReadPipelineInformation(), and X.refresh() to no avail.
Any Ideas?
yeharav is offline   Reply With Quote
Old   February 26, 2016, 03:53
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
I would suggest to use the trace functionality. This would mean to do everything manually once, while tracing the steps, at the end stop the trace and than modify the python script that paraview gives you to your needs.
Regards,
Tom
tomf is offline   Reply With Quote
Old   February 26, 2016, 16:35
Thanks for the suggestion.
The script was actually produced by the trace feature.
My aim is to use the script outside of paraview (pvbatch, for example).
where the code that was produced by the trace feature did not load the time steps of the decomposed case.
When I used it in the paraview, I saw that I have to press the 'apply' button for things to work. However, I will try it again.
Old   February 28, 2016, 08:11
Default Problem Solved
The script is
X OpenFOAMReader(FileName='X.foam',CaseType = 'Decomposed Case')
X.UpdatePipeline([the time]).
To access the data we use the
import vtk.numpy_interface.dataset_adapter as dsa
slice1 = Slice(X)
rawdata =  servermanager.Fetch(slice)
data = dsa.WrapDataObject(rawData)
data.PointData ...
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
Simple channel case using cyclicAMI will not converge cbcoutinho OpenFOAM Running, Solving & CFD 3 August 4, 2015 12:28
[OpenFOAM] ParaView 4.10 and OpenFOAM 2.3.0 Multiregion and decomposed case romant ParaView 3 April 7, 2014 15:42
Error reading new case montag dp FLUENT 5 September 15, 2011 06:00
Turbulent Flat Plate Validation Case Jonas Larsson Main CFD Forum 0 April 2, 2004 10:25
