[OpenFOAM] Segmentation fault when using Glyph from Custom Source Filter in ParaFoam |
June 9, 2015, 16:48 |
Good Afternoon,
I have just installed Open Foam 2.4.0 Deb Pack along with ParaView OpenFoam 4.1 onto Ubuntu 14.04 and have been working on the lid driven cavity tutorial in the OpenFoam User Guide. When I go to show the velocity field with the arrows using the Glyph Filter ParaFoam crashes and gives an error: Segmentation fault (core dumped) Everything else has worked according to the User Guide this has been the only error I noticed so far. Any help would be appreciated, Jacob |
September 20, 2015, 22:07 |
Stab
Hi Jacob, were you able to find a solution to this issue? I am facing exactly the same problem after installing the latest versions of Ubuntu/OpenFOAM/paraFoam and starting with the tutorial cases.
Does anyone else know what the problem could be? |
[Other] Tabulated thermophysicalProperties library | chriss85 | OpenFOAM Community Contributions | 62 | October 2, 2022 03:50 |
[OpenFOAM.org] Patches to compile OpenFOAM 2.2 on Mac OS X | gschaider | OpenFOAM Installation | 136 | October 10, 2017 17:25 |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 17:34 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 01:22 |
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error | FerdiFuchs | OpenFOAM Community Contributions | 27 | April 16, 2014 15:14 |
