[OpenFOAM] Adding a geometry to interDyMFoam results |
September 9, 2015, 07:30 |
Pascal Balz
Rep Power: 11 |
I simulated a interDyMFoam case with a ship-like structure. For visualization I use a alpha iso-surface for the water surface and the hull (wall) for the ship. This works without any problems. For better visualization (and just for visualization) I would like to add another geometry, let's say a car (of course it's not a car... ), on top of the hull at a fixed location. Importing the geometry as a stl file results in a static geometry. Obviously I want the car to move along with the hull so that it looks nice and physical. I dont want to rerun the calculation and the meshing process with the new geometry, as the car's geometry is rather complex. Computational time is about 3 days btw. Is there any possibility to fix the car to the hull so that the car moves exactly like the hull does? Thanks!
Regards, Pascal Last edited by pbalz; September 9, 2015 at 07:31. Reason: typos |
[ANSYS Meshing] 2D mesh from a 3D geometry results in 1m thick mesh | herrolsen | ANSYS Meshing & Geometry | 2 | March 26, 2019 15:00 |
Results are not converging for Full Aircaft Geometry | akki_malik | SU2 | 11 | September 24, 2018 11:21 |
chtMultiRegionSimpleFoam: strange error | samiam1000 | OpenFOAM Running, Solving & CFD | 26 | December 29, 2015 22:14 |
[DesignModeler] Error while Loading a Geometry | JD944 | ANSYS Meshing & Geometry | 0 | October 25, 2011 14:51 |
error using interDyMFoam with kOmegaSST to simulate sloshing | anmartin | OpenFOAM Running, Solving & CFD | 0 | July 20, 2010 13:21 |
