Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Parallel Rendering of openFOAM with pvserver
Old   September 30, 2015, 15:13
Default Parallel Rendering of openFOAM with pvserver
Leonard Cassady
im_lenny is on a distinguished road
I'm attempting to use pvserver to accelerate the post-processing of my openfoam solution. I have a 48 core machine. I have correctly installed and compiled a parallel copy of paraview 4.1.0 with OpenFOAM 2.4.x. If I open a simple .obj file I can see that different parts of the surface are rendered using different processors. I can also see that the memory is shared among the parallel processes.
When I open a reconstructed openFOAM solution with 20 million cells with paraview connected to 40 process pvserver, the image seems to be rendered (or processed) with only 1 processor. Is there a step that I'm missing to parallelize the reconstructed Openfoam data files for rendering?
im_lenny is offline   Reply With Quote
Old   October 1, 2015, 10:33
Default Update from OpenFOAM
Leonard Cassady
The paraview reader for OpenFOAM data is not written for distributed processing. That is why native OpenFOAM files can't be visualized in parallel with pvserver.
Does anyone know the most efficient (time and storage) method for post-processing large OpenFOAM solutions? I have a time series of 6 second length recorded at 200 Hz with 20M cells.
openfoam 2.4.x, paraview 4.1.0, pvserver
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 05:29
OpenFOAM 5.0 Released CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 11 June 5, 2018 23:48
[Commercial meshers] OpenFoam Mesh to Fluent Mesh in parallel case DominicTNC OpenFOAM Meshing & Mesh Conversion 3 November 22, 2017 09:19
Problem in Running OpenFoam in Parallel himanshu28 OpenFOAM Running, Solving & CFD 1 July 11, 2013 09:19
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
