Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] How to calculate mass flow rate through arbitrary rectangle plane in paraview
Old   March 10, 2016, 02:53
Default How to calculate mass flow rate through arbitrary rectangle plane in paraview
Manoj
manoj_nav is on a distinguished road
Hi All,
I am trying to calculate mass flow rate at 12 HVAC vents opening. These openings are not defined as patch or face. They are interior of the domain. I want to define plane/rectangle of a give size at these opening locations to calculate the mass flow rate through them. But when I create a plane in paraview using sources > plane, the plane doesn't have nay data field - U or p.
Please help me to calculate mass flow rate at arbitrary plane in the domain. When I use slice or cut plane, it cuts through the whole domain, which I don't want.
Regards,
Manoj
manoj_nav is offline   Reply With Quote
Specify mass flow rate for periodic boundary conditions in channel flow lion1990 OpenFOAM Running, Solving & CFD 1 July 9, 2018 17:46
Pressure Outlet Targeted Mass Flow Rate LuckyTran FLUENT 1 November 23, 2016 10:40
Periodic channel flow with time dependent mass flow rate QBeast FLUENT 3 May 10, 2013 13:14
Discrete Phase & Mass Flow Rate MagnusZeus FLUENT 0 December 2, 2011 17:57
particle, parcel and mass flow rate balance flybird FLUENT 0 May 24, 2007 10:44
