Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Paraview Cp Plot
Old   June 11, 2009, 05:32
Default Paraview Cp Plot
Prapanch Nair
prapanj is on a distinguished road
I have the FOAM results for a external flow problem ( 2 D). I want to see the plot of Cp around the object. How do I do that using paraview?
I tried to open the object patch and use plot over line on it. But the line is a straight line. Is there a way to conform a line over the object's surface and then plot Cp along that line?
How do I do this in 3D. Is there another way in OpenFoam to obtain Cp over a object?
Thank you
Prapanj.
prapanj is offline   Reply With Quote
coefficient of pressure, openfoam, paraview
[OpenFOAM] Plot over line average magnitude of particle velocity in paraview maysmech ParaView 13 August 12, 2022 11:46
[OpenFOAM] How to plot flow rate over time with Paraview sekunda ParaView 17 July 23, 2020 13:14
Vector Plot without using paraView DominicTNC OpenFOAM Post-Processing 1 August 25, 2017 04:11
Different results using sample utility vs Paraview 'Plot over line' tool agarwa58 OpenFOAM Post-Processing 5 March 20, 2016 08:57
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 21:41
