Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Plot over line different cases
Old   November 27, 2008, 05:45
Default Plot over line different cases
ep4
Pattyn Eric
ep4 is on a distinguished road
i would like to "plot over a line" the temperature of different cases (same geometry but different meshes, different turbulence models) in the same graphic in order to compare easely the different simulations. I only can plot variables of one case. It means that if i have two cases, i have automatically two graphics.
Is it possible to do that with paraview?
An other possibility would be to export the values of each separated graphs and to use an other tool to make one graphs with the different curves. Is it possible to write a text file or export the values of my plot over line?
ep4 is offline   Reply With Quote
Old   November 27, 2008, 11:47
Default use utility sample
mkraposhin's Avatar
Matvey Kraposhin
mkraposhin is on a distinguished road
use utility sample
mkraposhin is offline   Reply With Quote
[Gmsh] Structured meshing in Gmsh the_phew OpenFOAM Meshing & Mesh Conversion 19 August 24, 2022 03:19
Derivative of velocity and mean velocity hiuluom OpenFOAM Post-Processing 1 May 29, 2015 23:42
8x icoFoam speed up with Cufflink CUDA solver library kmooney OpenFOAM Running, Solving & CFD 42 November 6, 2012 11:37
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
Problems of Duns Codes! Martin J Main CFD Forum 8 August 14, 2003 23:19
