Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Volume rendering in paraview33
Old   October 4, 2008, 15:35
Default Volume rendering in paraview33
Martin Aunskjaer
aunola is on a distinguished road
I'm having no success with volume rendering. According to the Paraview Guide ch.4 this should be pretty straight forward: just select volume rendering, and it should work provided the mesh is all-tetrahedra.
Regardless of whether I first tetrahedralize the mesh via a filter or not I get the same behaviour: OpenGLProjectedTetrahedraMapper is executed (as indicated below the viewer window) repeatedly and for a very long time. When it finaly terminates, whenever I select something, like adjusting the opacity or choosing a filter, it starts all over. And while all this is going on, I never get an actual volume rendering.
I tried a small 1 million cell case, and after 1 hour I still had not gotten a volume rendering.
I'm running Fedora 9, 1.5.x build from sources, qt-4.3.2 build from sources and paraview 3.3 build from sources.
Anyone with similar problems ?
aunola is offline   Reply With Quote
snappyhexmesh remove blockmesh geometry philipp1 OpenFOAM Running, Solving & CFD 2 December 12, 2014 10:58
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 07:47
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
[Commercial meshers] CuBit t42 OpenFOAM Meshing & Mesh Conversion 6 July 10, 2008 07:51
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
