Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Parafoam problem
Old   March 4, 2008, 07:34
Default Parafoam problem
Mohsin Mohd Sies
mochzeen is on a distinguished road
I'm in the install/testrun phase of openfoam 1.4.1. Installing all binaries of openfoam and using paraview 3.2.1 (latest) which was installed systemwide. Everything else is running fine (java, gcc installed systemwide as opposed to under a subdirectory within /home/openfoam). The problem is when running parafoam, i got this error message;
Got unknown argument: paraFoam.pvs
paraFoam.pvs is there, so is the parafoam.pvs that came with openfoam1.4.1 not compatible with paraview 3.2.1 since the paraview that comes with openfoam is paraview 2.4.4?
Anyway to solve this? Thanks
mochzeen is offline   Reply With Quote
Old   March 4, 2008, 07:51
Default Hi The paraFoam works to my
Jens Klostermann
jens_klostermann is on a distinguished road
Hi
The paraFoam works to my knowledge only with the paraview 2.x.x not with the paraview 3.x.x.
Just download the paraview which comes with OpenFoam.
There is possibility to use paraview > 3.2.2 (or so) with a native reader, check the forum Native ParaView Reader
Jens
jens_klostermann is offline   Reply With Quote
Old   March 4, 2008, 19:31
Default Thanks Jens! Ooooo... more rea
Mohsin Mohd Sies
Thanks Jens! Ooooo... more reading and sleepless nights for me...
Old   March 17, 2008, 11:49
Default ParaFoam crashes in my install
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
ParaFoam crashes in my install of Ubuntu 7.10. and kills my session and restarts to the user login screen. Has anyone had this problem recently and how did you resolve it? My installation worked about 2 months ago before I switched to Fluent...now that I'm back on OF, using paraview/parafoam and it seems to hate me. Thoughts?
chegdan is offline   Reply With Quote
Old   April 8, 2008, 14:22
Default Hi I am novice running OF o
Juhani Aittamaa
jussi is on a distinguished road
Hi
I am novice running OF on Ubuntu 7.10. I managed to get the installation system check and installation test passed with only following two unset env variables. $LAM_ARCH_PATH is mentioned critical. (see below)
I did manage to run first example with icoFoam cavity and could use FoamX. There the double click was not functional instead right mouse click seemed to do the job.
I was not able to start paraFoam but found following error message.
What should i do
juhani@ubuntujuhani:~/OpenFOAM/OpenFOAM-1.4.1/bin$ paraFoam $FOAM_RUN/tutorials/icoFoam cavity
/home/juhani/OpenFOAM/linux64/paraview-2.4.4/lib/paraview-2.4/paraview-real: error while loading shared libraries: libtcl8.4.so: cannot open shared object file: No such file or directory
$LAM_ARCH_PATH --------- env variable not set --------- yes
$MPICH_ARCH_PATH --------- env variable not set --------- no
Checking the FOAM env variables set on the LD_LIBRARY_PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$FOAM_LIBBIN ...M/OpenFOAM-1.4.1/lib/linux64GccDPOpt yes yes yes
$FOAM_USER_LIBBIN ...OAM/juhani-1.4.1/lib/linux64GccDPOpt yes yes no
jussi is offline   Reply With Quote
Old   April 9, 2008, 03:32
Default @Daniel, I've had this pro
Andrew King
andersking is on a distinguished road
@Daniel,
I've had this problem and filed a bug report for ubuntu https://bugs.launchpad.net/ubuntu/+s...el/+bug/181943
It may be fixed in the next release of ubuntu (due shortly). It might be worth leaving a comment if your graphics card is not the same as mine (mine's an intel X3100).
Cheers,
Andrew
Dr Andrew King
Fluid Dynamics Research Group
Curtin University
andersking is offline   Reply With Quote
Old   April 9, 2008, 13:11
Default Andrew, what a coincidence.
Daniel P. Combest
Andrew,
what a coincidence... mine is also an intel X3100 GMA965. However, paraFoam will work slightly (crash only on more intensive and complicated geometries) if you run it in safe mode, disable all of the fancy effects, and talk really nice to your computer. I found that useful as a short term fix. I hope it will be fixed in the next release of Ubuntu!
Dan
Old   September 22, 2008, 02:59
Default Andrew, Daniel, I have simi
Mark Couwenberg
markc is on a distinguished road
Andrew, Daniel,
I have similar problems: starting paraview causes Linux / KDE to logout. It happens with paraview 3.2.1 but also with version 2.4.4. Videocard is MGA G550 AGP. However some time ago I had the same on a labtop with a different card (Intel if I am right). There I resolved the issue by installing paraview-3.2.1. However now this shows not to work. I probably have to update some package but I have no idea which one.
Any ideas here?
Brgds,
Mark
markc is offline   Reply With Quote
Old   September 22, 2008, 11:16
Default Mark, I wish I could help.
Daniel P. Combest
Mark,
I wish I could help. I ended up either updating Ubuntu 7.10 to 8.04 or reinstalling Ubuntu out of frustration. I imagine that this isn't an option for you and its a bit overkill. I am running Paraview 3.3 pretty well right now without any problems.
I do remember that I logged into safe mode to make things usable. Also disabling desktop effects seemed to be a big part of the problem as well as removing all of the fancy desktop effects completely. After those changes, I believe it worked.
Dan
Old   September 22, 2008, 12:33
Default Hi Mark Try to add the foll
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Mark
Try to add the following to
/etc/X11/xorg.conf
in the section "serverLayout"
Option "AIGLX" "false"
I did help on some graphical problems. What it does, is that it turn off all special effects as mentioned by Daniel.
/ Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   September 22, 2008, 15:36
Default Hi Niels, Dan, Thanks for y
  #11
Mark Couwenberg
Hi Niels, Dan,
Thanks for yuor help. I tried already the Option AIGLX false. It looked like it worked: paraview continued to start without logging off. However then I was not able to do anything. The buttons did not react on any click.
paraview.org isn't very helpfull here as well.
Search continues,
Mark
Old   September 22, 2008, 16:49
Default Sorry to hear that it didn't h
  #12
ngj
Sorry to hear that it didn't help. I had similar problems with complete crash of X11 on Fedora 9, and installed Ubuntu 8.04.1.
Here the AIGLX solved the problems.
/ Niels
Old   September 22, 2008, 17:46
Default Hi,I use Fedora9,have ever had
  #13
lin
Hua Zen
lin is on a distinguished road
Hi,I use Fedora9,have ever had similiar but not the same problem when I use "visit". If I click on any menus,then X was killed and I was kicked out immediately.
The time to find the reason is really long,finally I find that ,If I delete the line with "backingstore" in xorg.conf,then everything is ok. This staff was added by myself for some reason.
So my advice is that,if you have ever changed the xorg.conf file,just restore it to the original file and check whether it works.Losing some functionality is better than get X killed.
lin is offline   Reply With Quote
[OpenFOAM] Visualization problem on ParaFoam Rider ParaView 10 June 27, 2016 10:19
[blockMesh] Problem with arc edge, arc doesen't appear in ParaFoam A.A. OpenFOAM Meshing & Mesh Conversion 2 September 4, 2012 07:01
Problem with paraFoam Arenio OpenFOAM 0 April 12, 2011 05:41
Graphics problem in ParaFoam Tarak OpenFOAM 0 October 28, 2010 19:10
[blockMesh] Problem using paraFoam to view cavityGrade mesh file felik9 OpenFOAM Meshing & Mesh Conversion 1 September 27, 2009 15:31
