August 12, 2008, 06:47 |
ParaFoam StreamTracer
Sebastian Gatzka
Rep Power: 20 |
Hello World.
When I selected the Stream Tracer Filter from the ParaView menu I get this error message inside the shell: # Error or warning: There was a VTK Error in file: /home/dm2/henry/OpenFOAM/linuxSrc/paraview-2.4.4/VTK/Filtering/vtkDemandDrivenPi peline.cxx (661) vtkCompositeDataPipeline (0xb1d3a78): Input port 0 of algorithm vtkDistributedStreamTracer(0xaeb4ef0) has 7 connections but is not repeatable. ErrorMessage end I doesn't look like it has severe consequences, but does anybody know whats wrong?
Schrödingers wife: "What did you do to the cat? It's half dead!" |
August 19, 2009, 15:24 |
streamlines not showing
John
I am trying to display streams over a cylinder using streamtracer, which works fine (when the cylinder is in the center of the block), but when I move the cylinder away from the center of the mesh block, paraFoam doesn't display the streams even though the log file has U and p data. How do I display the streams? Thanks. |
[OpenFOAM] Unable to launch parafoam & | boonhow | ParaView | 5 | March 23, 2022 08:09 |
[OpenFOAM.com] paraFoam cannot open due to Qt issues - [Solved/Information] | u2berggeist | OpenFOAM Installation | 2 | July 2, 2018 17:03 |
[OpenFOAM] How to use paraFoam on a cluster | andreas | ParaView | 1 | March 6, 2013 17:11 |
[OpenFOAM] OpenFoam (Ubuntu): paraFoam via Xming+PuTTY | raketenmaid | ParaView | 4 | February 5, 2013 05:20 |
[OpenFOAM] Parafoam basic questions | qtian | ParaView | 0 | July 20, 2007 11:52 |
