[OpenFOAM] Is that a circle Results from interFoam |
May 7, 2008, 15:37 |
Sebastian Gatzka
Rep Power: 20 |
I have to compare a liquid volume with a circle.
It's the output from a simulation. I thought about creating the contour-plot for gamma=0.5, which does look really good like a circle. But how am I going to get addition data corrosponding to a circle inside this plot? Or do I have to export the contour plot so I can handle the comparison in an other software - like MATLAB, or something similar? Does anyone have an idea about how to export contour-plots?
Schrödingers wife: "What did you do to the cat? It's half dead!" |
May 7, 2008, 17:08 |
Hello Sebastian!
I don't qu
Bernd F.
Rep Power: 17 |
Hello Sebastian!
I don't quite understand your problem. Maybe you should attach your output file. You compare a volume with a circle. Is your question, how well a certain contour of a 2D cut of the gamma field correlates with a circular curve? If you want to compare these visually you can add a cylinder or sphere source in paraFoam an overlay them with your solution. For a quantitative comparison you can save the output in paraFoam in any data format that you are able to read into your Mathematica or whatever. Bernd |
May 8, 2008, 02:49 |
Yes. That's exactly what I pla
Sebastian Gatzka
Rep Power: 20 |
Yes. That's exactly what I planned to do.
But how is it possible to export such data from ParaView. I haven't seen any export function or similar.
Rising Bubble Test Case Using interFoam: Unrealistic Results?! | farazarbabi | OpenFOAM Running, Solving & CFD | 21 | May 7, 2021 08:45 |
Channel flow using InterFOAM | DanM | OpenFOAM Running, Solving & CFD | 49 | July 31, 2020 11:43 |
Problem: Very long "write" time (~2h-3h) for results and transient results | Shawn_A | CFX | 16 | April 12, 2016 20:49 |
Using results from experiment | studygroups2000 | FLUENT | 0 | November 25, 2015 17:29 |
Microchannel flow interfoam. (results far away from theoritical answers) | Saideep | OpenFOAM Running, Solving & CFD | 1 | June 24, 2015 12:09 |
