Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Newer
Old   December 21, 2007, 06:09
Default Newer
weihong yao
ivanyao is on a distinguished road
when I follow the "tutorials",there is some errors.i don't understand how to type
paraFoam <root> <case>
if user name is ivan and the case name is "cavity".how to type it in order to show the Paraview?
ivanyao is offline   Reply With Quote
Old   December 21, 2007, 11:39
Default I once again request you to re
jaswi is on a distinguished road
I once again request you to read the user guide. Its all in there. Forum users assume that you have read the user manual.
Anyways I try to answer your question:
OpenFOAM commands have a general format:
command <root> <case>
where <root> is your root directory
where <case> is the directory where you case lives
before executing a command make sure that you know what is your <root> and <case>
now with your username your shell prompt should be something like:
ivan@hostname:~>
cd to the directory where your case lives so that when you do ll it should list you case directory
Then try
ivan@hostname:~> paraFoam . cavity
In the above example your <root> is the current directory "." and cavity is your <case> directory.
For more info check out some Linux forum.
Hope that helps
Jaswinder
jaswi is offline   Reply With Quote
Old   December 22, 2007, 00:05
Default thanks
weihong yao
thanks
Old   December 22, 2007, 00:08
Default thanks i try it.
weihong yao
thanks i try it.
pyFoamTimelinePlot with newer Openfoam versions arieljeds OpenFOAM Post-Processing 0 June 6, 2016 09:46
Ansys older version to newer? Ansys 13 to lower version? paka ANSYS 2 November 28, 2013 12:29
(x-post from 'bugs') mesquite-2.1.2 compile fix for newer gcc kmooney OpenFOAM Installation 1 May 9, 2012 17:32
newer version of Fluent/ CFX Vs. CFX11?!? mohammad CFX 3 May 26, 2011 09:38
patchTool, is there a newer alternative? bigphil OpenFOAM Pre-Processing 4 October 19, 2009 07:56
