Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] FoamToVTK Animation with Paraview 3
Old   October 5, 2007, 09:52
Default FoamToVTK Animation with Paraview 3
Pierre-Olivier Dallaire
podallaire is on a distinguished road
Good morning guys,
I've been using paraview 3 and paraview 2-6 for the last two weeks to check my OpenFOAM results. In order to visualize my results with Paraview 3 (paraFoam will not work), I used the foamToVTK converter (which works very well) and opened the VTK files with Paraview 3. The only thing is that I'm not able to get an animation in Paraview 3 with all my time steps. Any idea on how to do it ? All time steps where converted with foamToVTK.
Best regards,
PODallaire
podallaire is offline   Reply With Quote
Old   October 7, 2007, 15:27
Default Animations didn't work with 3.
Assistant Moderator
Bernhard Gschaider
Animations didn't work with 3.0 AFAIK. I don't know if 3.1 or 3.2 is the first version to support that
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   October 7, 2007, 19:00
Default Hi Pierre-Olivier, There's an
Takuya OSHIMA
7islands is on a distinguished road
Hi Pierre-Olivier,
There's an entry on ParaView Wiki.
http://paraview.org/Wiki/Animating_l...TK_file_series
Looking around the source tree it seems the latest CVS seems to have this feature built-in (I haven't tested it myself though)
Takuya
7islands is offline   Reply With Quote
Old   October 8, 2007, 07:47
Default Bernhard and Takuya, thanks
thanks for messages. I'll take a look on the paraview wiki
as suggested by Takua.
PO
Old   October 9, 2007, 00:26
Default Hi, as mentionned on the wi
as mentionned on the wiki, Paraview as a "multi-file" reader
for VTK legacy files. I tried it but even if it looks that it is opening
a group of files, it seems that only one random file will open.
Did you try it Takuya ?
Thanks
PO
Old   October 9, 2007, 07:26
Default Hi, Yes it worked with today'
Takuya OSHIMA
Yes it worked with today's CVS version. Note that you need to select group name on the right of disclosure mark (the blue highlighted "blow..vtk" in the Wiki case), not individual timestep files.
Takuya
[OpenFOAM] Paraview 3.12 memory allocation problem while saving animation jgomez ParaView 17 September 14, 2013 17:03
[OpenFOAM] plot particles and animation in paraview phsieh2005 ParaView 1 July 26, 2013 05:35
[General] Paraview nice animation PyGloo ParaView 4 June 7, 2012 12:34
Paraview 3.12 - How to compile with ffmpeg for animation tunkers OpenFOAM Installation 6 January 21, 2012 21:08
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 21:41
