Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Plot the whole cylinder from a wedge data
Old   February 10, 2007, 15:50
Default Plot the whole cylinder from a wedge data
Pei-Ying Hsieh
hsieh is on a distinguished road
Dear Paraview experts:
I ran an axi-symmetric case (wedge). Is it possible to plot the whole cylinder from the wedge data?
Thanks!
Pei
hsieh is offline   Reply With Quote
Old   February 12, 2007, 07:51
Default In principle yes, but it's not
Assistant Moderator
Bernhard Gschaider
In principle yes, but it's not that easy.
It depends on what you want.
- One possibility is to use clever combinations of the Transform and the Group Filter
- The other possibility is the RotationalExtrusion-Filter (but this one works only on "line-like" objects (for instance an iso-surface on a plane)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   February 13, 2007, 10:30
Default Thanks Bernhard! I will giv
Pei-Ying Hsieh
Thanks Bernhard!
I will give these two approaches a try.
Pei
[General] Extracting ParaView Data into Python Arrays Jeffzda ParaView 30 November 6, 2023 21:00
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 07:31
[General] Line plot with cell data: PlotOverLine ? francois ParaView 1 January 3, 2015 20:06
[OpenFOAM] Overlay scatter plot of experimental data on 'plot over line' in ParaView gcengineer ParaView 4 August 6, 2013 19:35
Plot data for a fixed point aut_iut OpenFOAM 0 December 23, 2010 05:16
