March 22, 2006, 00:01 |
Running paraFOam
HI
I am just starting to learn OpenFoam and have been going through the tuts from the user guide. When I try to view the mesh for the case cavity (2.1.2 of the User Guide) I get a window which looks very different from Figure 7.1. The current window has 3 tabs labelled: General, annotate and camera instead of parameters, display and information. I had problems running paraFoam earlier (ie segmentation fault, line 57 in paraview) so I commented that entire file and finally got it to open. It's just that the windows doesn't look the way it should. SHuo |
March 23, 2006, 04:11 |
Your paraFoam installation is
Mattijs Janssens
Rep Power: 26 |
Your paraFoam installation is not correct. Fix it or use
- foamToVTK to convert results to vtk format - paraview and load in the .vtk files |
March 26, 2006, 19:16 |
I tried running it again and i
I tried running it again and it seems that the error is because the file cavity.foam is empty. Any advice?
September 13, 2006, 23:42 |
That troubles me too. Have you
Wei Zhang
Rep Power: 17 |
That troubles me too. Have you solve the problem? How? Thanks a lot!
Joey |
September 14, 2006, 07:31 |
Hi Joey!
You're refering to t
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Hi Joey!
You're refering to the post from the 267th of March, are you? As far as I understand it the cavity.foam file is supposed to be empty. It only tells the paraview importer "In this directory you'll find OpenFOAM-data"
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
October 23, 2006, 09:27 |
Hej,
Hej,
I am just starting to learn OpenFoam and have been going through the tutorials from the user guide. I have some problem with paraFoam..I am trying to run it , but I get a message: ---------------------------------------------------- home/margst/OpenFOAM/OpenFOAM-1.3/bin/paraFoam: case directory /home/margst/OpenFOAM/margst-1.3/run/cavity does not exist, exiting ---------------------------------------------------- I typed: paraFoam $HOME/OpenFOAM/margst-1.3/run cavity -------------------------------------------------- Could u help me, please? |
October 23, 2006, 09:40 |
Hej,
I solved one problem, bu
Hej,
I solved one problem, but now I have got another one: /home/margst/OpenFOAM/OpenFOAM-1.3/bin/paraFoam: line 57: paraview: command not found Anyone know what I should do? /Rita |
October 23, 2006, 09:51 |
Why cannot you find paraview?
Hrvoje Jasak
Rep Power: 33 |
Why cannot you find paraview? Did you install it? What happens if you say:
which paraview Are you sure it is on the system? Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
October 23, 2006, 10:02 |
Hej Hrvoje,
After I typed:
#9 |
Hej Hrvoje,
After I typed: which paraview , nothing happens. Should I install paraview separately? It's seems the paraview is not installed. do u know how to install it? thank you, Rita |
October 24, 2006, 05:38 |
Hi Margarita,
Have you rea
#10 |
Makoto Ueno
Rep Power: 17 |
Hi Margarita,
Have you read README in OpenFOAM-1.3? It seems that you have not set the environment variables. Before running paraview, you should type following command (if you're using bash) to set environment variables. ---------------------------------------------- . $HOME/OpenFOAM/OpenFOAM-1.3/.OpenFOAM-1.3/bashrc ---------------------------------------------- Anyway, I recommend you to read the README file before doing that. Makoto |
October 24, 2006, 08:48 |
It seems that you did not inst
#11 |
Dragos
Rep Power: 20 |
It seems that you did not install the third party software:
gcc, paraview and jdk Did you follow the steps I wrote for you? If you did, then you have to find in OpenFOAM/linuxAMD64 the following: home/dragosm> ls OpenFOAM/linuxAMD64/ gcc-4.1.0 j2sdk1.4.2_05 paraview-2.4.2 There you have a directory called paraview-2.4.2 which contains all the binaries for paraview. Dragos |
October 26, 2006, 14:43 |
Thank you all, I finaly instal
#12 |
Thank you all, I finaly installed all part of OpenFOAM.
/Rita |
Error problem while running sadia d lts tutorial | kane | OpenFOAM Running, Solving & CFD | 2 | May 26, 2018 03:38 |
License trouble: ANSLIC_ADMIN, FLEXlm not running, but two lmgrd processes running! | dancoz87 | ANSYS | 17 | November 14, 2016 01:10 |
paraFoam "Fatal Error" on Debian Wheezy/Sid | ned800 | OpenFOAM Installation | 3 | October 24, 2012 11:26 |
[OpenFOAM] ParaFoam Error | jblucca | ParaView | 1 | June 28, 2007 02:37 |
[OpenFOAM] Both paraview and paraFoam crash on Redhat Linux WS v4 64bit | sek | ParaView | 4 | August 17, 2006 16:26 |
