Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Both paraview and paraFoam crash on Redhat Linux WS v4 64bit
Old   August 17, 2006, 09:45
Default Both paraview and paraFoam crash on Redhat Linux WS v4 64bit
sek
Sung-Eun Kim
sek is on a distinguished road
Running either paraview or paraFoam crashes immediately after entering the command line. It seems to launch paraview, showing the paraview logo in a split of second. But it crashes instantly and even logs me off! I'll appreciate if anyone can enlighten me with any clue to what's happening and trouble-shooting.
sek is offline   Reply With Quote
Old   August 17, 2006, 09:49
Default I should've said I'm using Ope
sek
Sung-Eun Kim
I should've said I'm using OpenFOAM 1.3 along with paraview 2.4.3.
Old   August 17, 2006, 12:14
Default I had a similar problem on ubu
ziad is on a distinguished road
I had a similar problem on ubuntu dapper drake 64bit and several versions of paraview. posted but no replies yet. see
http://www.cfd-online.com/OpenFOAM_D...tml?1155406587
It is a resource problem but since there is enough memory (512Mb) I suspect this might be the compiling options of paraview. doesn't seem to be connected to foam since it runs just fine in 64bit, so probably have to recompile...
ziad is offline   Reply With Quote
Old   August 17, 2006, 15:15
Default I tried to rebuild paraview. B
sek
Sung-Eun Kim
I tried to rebuild paraview. But I got the following error while trying to compile. Has anybody seen this before? I don't quite understand why the linker bothers with /usr/lib/libGL.so? I thought it should look for /usr/lib64/libGL.so, as my CMakeCache.txt file says.
[sek@KimS paraview-2.4.4-obj]$ make
-- Found existing Tcl, not rebuilding
-- Found existing Tk, not rebuilding
Linking CXX shared library ../../../bin/libvtkftgl.so
/usr/bin/ld: skipping incompatible /usr/lib/libGL.so when searching for -lGL
/usr/bin/ld: cannot find -lGL
collect2: ld returned 1 exit status
make[2]: *** [bin/libvtkftgl.so.pv2.4] Error 1
make[1]: *** [VTK/Utilities/ftgl/CMakeFiles/vtkftgl.dir/all] Error 2
make: *** [all] Error 2
Old   August 17, 2006, 16:26
Default how about linking /usr/lib/lib
how about linking /usr/lib/libGL.so temporarily to /usr/lib64/libGL.so? just for building paraview. you can reset the links after. might solve your problem.
[OpenFOAM] Installation of ParaView on Ubuntu that exists in (Windows Subsystem Linux) k.farnagh ParaView 8 November 20, 2023 09:40
[OpenFOAM.com] paraFoam cannot open due to Qt issues - [Solved/Information] u2berggeist OpenFOAM Installation 2 July 2, 2018 17:03
Parafoam - FATAL ERROR: ParaView reader module libraries do not exist Amit_Pawarpawar OpenFOAM Installation 1 August 25, 2014 10:31
Paraview crash Nixlax OpenFOAM Installation 4 February 15, 2014 17:21
[OpenFOAM] parafoam - paraview help function felik9 ParaView 5 June 3, 2010 15:03
