Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Turbulent intensity and viscosity ratio
Old   June 30, 2006, 13:15
Default Turbulent intensity and viscosity ratio
Greg Zink
gzink is on a distinguished road
What is the best way to visualize contours of turbulent intensity and viscosity ratio in paraFoam? Does this require adding code in Foam itself, or is there a way in paraFoam to calculate them from k and epsilon?
Thanks!
Greg Z.
gzink is offline   Reply With Quote
Old   June 30, 2006, 17:10
Default Easiest to add code in Foam -
Gavin Tabor
grtabor is on a distinguished road
Easiest to add code in Foam - either to your main code (add extra fields) or write a post-processing code to read in k,e and write out TKE and viscosity ratio.
I doubt that its possible in paraFoam
Gavin
grtabor is offline   Reply With Quote
Backflow Turbulent Intensity and Viscosity Ratio for cntrol vol.opening to asmosphere oozcan FLUENT 0 November 28, 2016 08:00
turbulent intensity & viscosity ratio Braham FLUENT 2 August 20, 2015 13:47
External flow turbulent intensity and turbulent viscosity ratio Anna Tian Main CFD Forum 9 February 1, 2014 22:14
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel nuimlabib Main CFD Forum 0 August 4, 2009 00:05
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 06:13
