Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Time Step Data Question
Old   June 1, 2006, 10:39
Default Time Step Data Question
Terry Jordan
tj22 is on a distinguished road
Looking through the examples I see different data between most time 0 and the next step say .01, while it seems the other step sasy 0.01-1.0 all have the same data files.
My question is: Is this always the case? Will the other timesteps say 0.01-1.0 always have all the same data files?
tj22 is offline   Reply With Quote
Old   June 1, 2006, 13:39
Default Usually codes dump out more fi
Mattijs Janssens
mattijs is on a distinguished road
Usually codes dump out more fields (e.g. 'phi') than they need to start.
The starting point is not always time 0, you quite often restart from an existing time.
(In the current paraFoam reader it actually scans through all time directories to pick up all the fields in all time directories)
mattijs is offline   Reply With Quote
Old   June 1, 2006, 15:42
Default Yeah I already worked it out a
Terry Jordan
Yeah I already worked it out and came up with the same solution.
[General] Extracting ParaView Data into Python Arrays Jeffzda ParaView 30 November 6, 2023 21:00
pimpleDyMFoam computation randomly stops babapeti OpenFOAM Running, Solving & CFD 5 January 24, 2018 05:28
Help for the small implementation in turbulence model shipman OpenFOAM Programming & Development 25 March 19, 2014 10:08
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 09:34
same geometry,structured and unstructured mesh,different behaviour. sharonyue OpenFOAM Running, Solving & CFD 13 January 2, 2013 22:40
